2010+ Future Cruze Discussions Discussions and information related to the upcoming 2010 Chevy Cruze
Vince buys a Cruze LTZ
Old 11-16-2010, 10:27 AM
  #51
BlackCobalt707's Avatar
my cars temp used to be up there at like 210. but lately its been sittin at about 174 for some odd reason. i dont know if i should be worried or happy lol
Old 11-16-2010, 10:30 AM
  #52
Terminator2's Avatar
Originally Posted by VinceTrifecta
Well, just got done doing some logging. There's most definitely room for improvement.
Here's some numbers from the stock tune:
Commanded AFR @ WOT (PE Mode): 10.3:1
Commanded Ignition Advance: 8*
Sustained boost: 15-16psi
Wastegate %: 74% of maximum potential
Engine Coolant Temp: 221*F
Wow 10.3 A/F and 8* of timing good job GM LOL.
Old 11-16-2010, 10:33 AM
  #53
elecblue06's Avatar
4-5 more psi 11.6:1 afr and some healthy timing seems like it's in order lol
Old 11-16-2010, 10:41 AM
  #54
philupondes's Avatar
this is awesome, Vince when you get this figured out my wife is going to kill you. LMFAO
Old 11-16-2010, 10:47 AM
  #55
cmatthewb101's Avatar
Subd
Old 11-16-2010, 11:02 AM
  #56
Is that cruze GDI?
Old 11-16-2010, 11:05 AM
  #57
elecblue06's Avatar
Originally Posted by Terminator2
Is that cruze GDI?
"Mechanical Fuel Injection" off the chevy site.. no DI here and i know i went on the richer side of AFR
Old 11-16-2010, 11:09 AM
  #58
Meh 11.5-12.2 works well normally. 20 psi 15* of timing and 11.8 A/F would be a good start.
Old 11-16-2010, 11:19 AM
  #59
elecblue06's Avatar
yea thats kinda what i was figuring should be interesting to see what happens when the car gets tuned. IMO it'll be a big gain or not much at all lol i would think it should be a decent gain but only time will tell depends on how that turbo likes running at 20 psi lol anyone have a compressor map for that turbo?
Old 11-16-2010, 12:50 PM
  #60
Tennpenn83's Avatar
sub'd
good work vince
Old 11-16-2010, 12:53 PM
  #61
shawn672's Avatar
Vince, hit me up if your Cruze doesn't blow up
Old 11-16-2010, 12:59 PM
  #62
Small motor very small turbo but it should gain a good percentage of total power. I do not think it is going to gain as much power has a LNF with a tune but it should be more fun to drive for sure.
Old 11-16-2010, 01:20 PM
  #63
Tundraboarder666's Avatar
I'm sure it could see 150whp do full boltons and tune it maybe 165 to the wheels. Just not fast enough for my taste. Oh Vince I need to send you my Dyno chart, totally forgot.
Old 11-16-2010, 01:29 PM
  #64
ripped's Avatar
The buick turbo regal is where it's at
The cruze isn't that bad. Saw one in person it's nice inside and out performance wise sucks but hey look at it this way for anybody who has to downgrade at least you can still have a little Eco box that's turbo and tune it.
Old 11-16-2010, 01:33 PM
  #65
spike's Avatar
sub'd
Old 11-16-2010, 02:02 PM
  #66
SuperchargedSS's Avatar
So basically gm gave up with the 4 cyl performance, and has released a great DD for the ZR1.
Old 11-16-2010, 02:07 PM
  #67
umrdyldo's Avatar
If you could get to roughly 145-150 whp, you could be about in line with a lightly bolted and tuned 2.2 cobalt. Only it's would cost about an 1/5th as much in mods.
Flamesuit engaged
Old 11-16-2010, 02:11 PM
  #68
army_greywolf's Avatar
development will take time but ive seen first hand gmpd developing what APPEARS to be an LNF or a varient thereof in the cruze as well as big brakes. of course plan to pay 30 grand for all that...
  #69
Flamesuit engaged
If thats the reality, then so be it. The 2.2 wasn't designed with performance in mind either.
Old 11-16-2010, 02:15 PM
  #70
Originally Posted by BlackCobalt707
your car is runnin at 220?
Not my car... the cruze
Old 11-16-2010, 02:16 PM
  #71
aight
Old 11-16-2010, 05:47 PM
  #72
Rent me! per hour
Area47's Avatar
the only thing that saves it, is the interior and stereo system. **** for power. transmission is very slow to shift in either direction. vibrates way too much at idle.
Old 11-16-2010, 07:16 PM
  #73
VinceTrifecta's Avatar
Flamesuit engaged
Realistically this is about where it will end up, I suspect. Percentage-wise, LNFs typically gain about 25% power, and this is because we spin the turbo at the same speed at lower elevation as it might spin at, say 12000 feet to still make 260HP at the crank. From the factory's perspective, that's the whole tuning principal - make it perform consistently.
The turbo runs about 75% of "max wastegate" right now. Another 25% might get us close to 22psi or so.
Hence, 121.2 (stock WHP) * 1.25 = 151.5 WHP
HOWEVER, the LUJ is NOT tuned as aggressively as the LNF is from the factory, so gains could possibly be bigger than 25%. We shall see. Hopefully I'll find out on Friday!
Old 11-16-2010, 07:19 PM
  #74
Is that cruze GDI?
It is port injected, although there are apparently plans in the works to do a SIDI (and HCCI capable) version of this little 1.4
I was a bit surprised it is port injected, myself, but maybe GM met their design goals for economy and power without DI (which adds extra cost)
Old 11-16-2010, 07:21 PM
  #75
Yes, the Regal will be one sweet machine (and fully flex fuel/E85 capable from the factory!). We're excited about getting our hands on those, too. We have someone lined up that's getting a Regal next month that will work with us on the tune.
Quick Reply: Vince buys a Cruze LTZ
