New MSD ignition product for Waste Spark Coil Packs
Old 11-16-2006, 07:53 PM
I'm old school
Halfcent's Avatar
http://www.msdignition.com/2007/light.html
I'm not entirely sure how to use these products. I have no experience with them. But I know people have been looking for an MSD ignition product for the L61 Ecotec for some time. This looks like it might be it.
Old 11-16-2006, 07:56 PM
CTORANGESC's Avatar
I have personally dyno tested the msd. Not on a cobalt but an Srt 4, and I can say is that it only gave 1 horsepower over the stock run. So honestly its not worth the money. I dont know if it will be diff for the cobalt, who knows. Maybe somebody will try it.
Old 11-16-2006, 08:00 PM
carbombss's Avatar
.......i was lookin at there 60 lbers has ne1 tried these ones yet
Old 11-16-2006, 08:47 PM
chevytech's Avatar
why though? unless your trying to make a retarded amount of horsepower our ignition set up is more than capable of igniting as much fuel as you could want. plus putting on an igniton system is not so much about making more horsepower as it is just trying to ignite a much higher amount of fuel either under heavy compression or under high boost. but if it uses multiple sparks to ignite the fuel it could do wonders for our air fuel and gas mileage
Old 11-16-2006, 08:53 PM
Witt's Avatar
I think they're just a neat and tidy version of the combined components listed in this how to: http://www.livewirerodimus.com/Ecotec/msd.html Used mostly for timing changes for engine management.
Old 11-16-2006, 09:05 PM
Rodimus_Prime's Avatar
Im the guy that wrote that btw^^^
Anyways you dont adjust timing on your msd box thats not what its for, the msd does help alot with gas mileage , power and a general smoothness through the rpms and at idle you just cant get with the stock ignition, this will only work with the 2002 - 2006 eco L61s as the 07 and later and all the 2.0/2.4 use the coil on plug which dont need an msd or really benefit
Also Id recommend getting msd coils for use with it the stock coils will run, but they dont last much more than 10-20k
Old 11-16-2006, 09:08 PM
Witt's Avatar
Awesome write up. I didn't even know that cam sync generator existed until I saw your article.
At the top of the article you mentioned being able to make timing adjustments, thats why I assumed anyone upgrading to that system was doing it to pull timing.
DarrenGC
12-24-2021 01:55 PM
717ssbalt
10-02-2015 04:01 PM
OrangeCoba
10-01-2015 10:00 PM
Extreme Dimensions
09-24-2015 07:51 PM
Quick Reply: New MSD ignition product for Waste Spark Coil Packs
