Bleeding the clutch
Old 11-15-2006, 02:08 PM
bdwarr6's Avatar
Bleeding the clutch
first of all let me ask can you just pop the clutch lincage on with the pin in it?
also what size wrench do i need for the nut on it, and are there any specific ways to bleed it
I have never bled a clutch before so please excuse the newb q's
Old 11-15-2006, 02:23 PM
bredick's Avatar
https://www.cobaltss.net/forums/show...leeding+clutch
Old 11-15-2006, 02:31 PM
bdwarr6's Avatar
i saw that but where do i run the vacume line to?
the thing that the clutch linkage is on that little nipple?
Old 11-15-2006, 02:32 PM
bdwarr6's Avatar
if you coud explain where to put each hose i would appreciate it
Old 11-15-2006, 02:45 PM
2K5SS/SC?'s Avatar
Just pop the linkage back onto the ***** with you hand and some effort. I'll be back in a sec with the clutch bleeding info.
Old 11-15-2006, 03:34 PM
2K5SS/SC?'s Avatar
Ok it was more than a second as it was hard to find. Check out this link as it has nice pics and everything!
https://www.cobaltss.net/forums/show...t=clutch+bleed
Old 11-15-2006, 03:39 PM
bdwarr6's Avatar
yea i got that, but where do i run the lines of the compressor thingy to? and do i need to remove **** out of the bay again/?
Old 11-15-2006, 11:56 PM
2K5SS/SC?'s Avatar
You attach the line of the vacuum pump to the rubber plug. You will need a barbed fitting for the hose to rubber plug. Push the plug into the resivour top where the cap would go and start pumping. It'll suck the air right out.
Old 11-16-2006, 12:37 AM
bdwarr6's Avatar
i tried it, i dont get any pressure
the dealer things says to put a vacume line from the fitting on the licage cable into a bottle of dot3 when you pump the clutch
Old 11-16-2006, 12:57 AM
2K5SS/SC?'s Avatar
I'm confused now. If your slave cylinder and lines are attached right you should see vacuum. The plug has to be pushed into the resivour to completely seal it off. Wedge it in there to ensure no air is leaking out. Then the lines should be air tight (zip ties on connections). You should be able to start pumping the Mity vac with the air release valve on the Mity vac closed. If you do not bleed the clutch by vacuum bleeding it, you won't get all the air out, and the clutch will not engage/disengage properly. The dealership needs to read how to bleed it propely because what they said is wrong.
Old 11-16-2006, 01:22 AM
bdwarr6's Avatar
i didnt zip tie connectors that could be a very good reason it doesnt work
05-28-2022 03:47 AM
Zharrington_2010LNF
02-08-2016 01:43 PM
RaginChopsuey
10-27-2015 01:27 PM
SSLOW06
10-01-2015 07:21 PM
Tupp
09-30-2015 08:18 PM
Quick Reply: Bleeding the clutch
