Balance shaft removal? Electric water pump?
Old 03-22-2015, 07:24 PM
TurboWood's Avatar
Hi Gents,
I've been doing some research on eliminating the balance shafts. Below are a few threads for reference. I have a few questions.
1) Is the GM racing kit still available (XGH676)? If so, where to buy?
2) If the GM kit is used does anyone make a bushing to block the front balance shaft bearing oil feed?
3) Has anyone here done either GM kit or Level Zero kit (retaining only the end of the balance shaft) and had any ill effects? I understand the vibration impact. I'm more curious about durability over time.
The next step would be an electric water pump. There are a few threads talking about it (in the Z22 link below it is talked about). My question is did anyone ever make a block-off plate for the factory water pump?
Removing Balance Shafts | Z22SE.co.uk
So it begins: engine removal Atom2 brammo 2006 Ecotec LSJ aka "Max".. - Page 3
https://www.cobaltss.net/forums/adva...on-kit-106411/
Daniel
bflo (05-20-2020)
Old 03-22-2015, 07:31 PM
South Central *********
JapEatr's Avatar
Level zero delete bushings and cut off the stock shafts
Use -12 fitting on the WP outlet and TStat inlet, davies craig waterpump
Old 03-23-2015, 09:27 AM
TurboWood's Avatar
quick draw mcgraw!
I think I know what you mean, but are you sure about the inlet/outlet direction? Are you talking about putting a fitting on the end of the pump (inline with the axis of rotation) or with a block-off plate on the block (removing the pump)?
Anyway, I appreciate the comments, but you've sort of jumped over my questions. I'm looking for the GM racing kit and/or a block-off plate for the water pump. Any thoughts?
Daniel
Old 04-06-2015, 07:13 PM
TurboWood's Avatar
For those interested I was able to find the GM Racing balance shaft elimination kit. GM had 2 left in stock so I bought them both. I'm intending on keeping one as a spare, but if someone wants it bad enough let me know.
Now for the fun part of figuring out how to block all the balance shaft bearing oil feeds.
Daniel
bflo (05-20-2020)
Old 04-06-2015, 07:45 PM
ItalianJoe1's Avatar
OTTP is selling the block off bushings, as well as Level Zero.
bflo (05-20-2020)
Old 04-08-2015, 09:27 AM
TurboWood's Avatar
Thanks for the reply. I knew about the Level Zero option, but the OTTP has an internal thread to help install/removal.
As I understand it these are for the rear balance shaft bearings. What about the front bearings? Do I need to plug them as well?
Daniel
Old 04-08-2015, 10:27 AM
JapEatr's Avatar
the front bearings we just cut the shaft down and use the sprockets and the cut off nub in place of the shaft
can you post a picture of the block off plate?
I may be interested
Old 04-08-2015, 07:06 PM
TurboWood's Avatar
It's not a block-off plate. It's a shorter chain and new chain guide. As you can see the new chain guide is attached in one of the balance shaft mounting holes. This means I need to plug the front bearings right?
bflo (05-20-2020)
Old 06-02-2015, 01:56 PM
JapEatr's Avatar
looks good
Old 06-03-2015, 12:38 AM
Doesnt make sense to me why theyd sell it without the oil block off
Old 06-14-2015, 03:30 AM
TurboWood's Avatar
My understanding is it was product of their racing department so they never made a full kit. They just sold the parts that needed tooling and figured buyers would figure it out.
Old 06-14-2015, 12:27 PM
TStone's Avatar
If you're gonna go ewp, then just cut the balance shaft chain, remove it, and then that's it...... Plumb in your EWP and go
Old 06-14-2015, 07:24 PM
mrbelvedere's Avatar
someone has a clue
Old 06-15-2015, 10:39 AM
TurboWood's Avatar
The reason for all this is I'm considering installing my scavenge pump where the stock water pump goes. This is why I want to move the water pump, but it means I would still need to drive something with the water pump chain.
The reason I want to do that is I don't have a lot of room around the engine to run the scavenge pump off the accessory belt, but an electric water pump can be mounted almost anywhere.
Daniel
bflo (05-20-2020)
Old 08-18-2015, 06:50 PM
TurboWood's Avatar
Done and done.
bflo (05-20-2020)
Old 09-24-2015, 11:19 PM
Chaos_Six's Avatar
TurboWood you have PM
Old 09-28-2015, 11:29 PM
cmiller8006's Avatar
So your not actually running an ewp?
Old 09-29-2015, 12:56 AM
TurboWood's Avatar
Not yet. I think I may have found a spot for my scavenge pump and I have enough work to get this thing running that I decided to wait.
Daniel
05-28-2022 03:47 AM
Solaris99
28
03-15-2017 01:22 PM
hacadacalopolis
10-28-2015 06:09 PM
ernnyyes
10-02-2015 05:16 PM
DANRICKARD
10-01-2015 12:08 AM
Quick Reply: Balance shaft removal? Electric water pump?
