Dual Pass intercooler
Old 01-25-2007, 04:35 PM
  #101
Blown 4-banger's Avatar
I don't know if I'd trust the dealer to do something like that on my car.
Old 01-25-2007, 10:18 PM
  #102
Cobalt_Supercharged's Avatar
The hardest part is drilling the endplate. If you are concerned about that buy the GM Dual pass plate and do the install. It's really not all that hard, just time consuming and requires a mild knowledge of working on cars.
Old 01-25-2007, 10:26 PM
  #103
Killa SS's Avatar
i kno how to work on cars. pull it apart put back together with new part. but its the hoses and switchin parts around for the flow thing that confuse and scare me.
Old 01-25-2007, 10:38 PM
  #104
South Central *********
JapEatr's Avatar
Originally Posted by BlackSS/SC
I just finished the dualpass endplate and the extra coolant bottle. I used the Ion Redline's stock coolant bottle and put it on the passenger side and made a couple simple brakets to hold it there on the stock studs that stick up there. Haven't been able to see the difference yet on IATs.... Too much damn snow
got pics of the bottle instal and brackets?
Old 01-25-2007, 10:41 PM
  #105
It's nothing really.
Old 01-25-2007, 11:26 PM
  #106
distillion's Avatar
Originally Posted by Cobalt_Supercharged
Here is my guide to doing the dual pass.
1) DISCONECT THE BATTERY and raise the front end of the car high enough for you to easily get under it. I normally leave the battery connected when instructions say to disconect it, but you will be using a wrench right next to the starter and from experience it arcs very well. Ask Blown 4-banger as our friend welded a wrench to Blown's starter.
2) Take off the S/C.
3) Remove the hoses from the IC pump and catch the fluid that drains.
4) Remove the IC pump and entire IC pump mounting bracket.
5) Remove the 2 bolts under the intake manifold. They are just barely above the IC mounting bracket bolts and not shown in the GMS3 instructions.
6) Remove the 7 fastners on the top of the manifold and remove.
7) Drain as much of the coolant from the manifold as possible. This will make the removal of the end plate and cores less messy.
8) Remove the bolts from the endplate and remove. It will take some force to pull it off. Be careful not to drop anything. There are 2 brass washers and 1 o-ring per core.
9) Remove the 2 cores. You can chose which ones you want and flip them. Just remember that the inlet has the small hole, the outlet has the large hole. Like the end plate, the cores are difficult to remove. I suggest going to a local Ace Hardware and getting some rubber jaw covers for your pliers to prevent scoreing them. There is a second set of washers and o-rings on the other side of the cores to look out for. The cores will make a horrible scritching sound as you are pulling them out. Just be gentle not to bend the fins.
10) Replace the cores with the small hole as the inlet for your new flow pattern and the large hole for the outlet.
11) Take the end plate to have the fitting welded in.
12) Replace the end plate and torque the bolts to the specs provided in the GMS3 instructions. (link posted in post #36)
13) Now would be a good time IMO to replace the stock intake manifold gasket with the revised version from GM if you haven't already ( http://www.crateenginedepot.com/stor...P1723C137.aspx ) and replace the intake manifold. Replace all the upper and lower fastners only hand tight then torque them according to the GMS3 specs.
14) Replace the IC pump mounting bracket and IC pump.
15) Reconnect all the coolant lines making sure the flow is going the proper direction for how you flipped the cores.
16) Refill and bleed the air from the system. I would suggest adding the extra resevior so you have a good place to bleed and extra coolant to prevent heat soak.
17) Replace the S/C and make sure everything is properly torqued and connected.
18) Take the car off the stands and take her for a spin. The real bennefits are the lower temps that allow you to add more timing to your tune whether it be for pump gas or race gas.
Feel free to ask questions if you need.
so if i get the plate, y connector and hose and follow this guide, im good to go?
Old 01-25-2007, 11:31 PM
  #107
I think so. It will take a few hours, so be prepared.
Old 01-25-2007, 11:32 PM
  #108
distillion's Avatar
one guy here said he did it in an hour??lol
this has to be the msot confusing mod ive ever wanted for my car hahahaha
Old 01-25-2007, 11:38 PM
  #109
If you are comfortable you could probably do it that fast. It took Blown 4-banger and I way, way to long simply because we weren't sure what we were getting into. 6 of those hours were dedicated to trying to figure out that there were 2 bolts holding the manifold on underneath.
Old 01-25-2007, 11:42 PM
  #110
distillion's Avatar
o damn, ok gotcha.
well when the time comes to where this will be done im letting the both of you know in advance you will be getting some pms regarding this hahaha, hope you guys dont mind!
Old 01-25-2007, 11:46 PM
  #111
No its cool. PM away, ask any questions you have... you know as long as their not like "what are you wearing?" ...nevermind
Old 01-25-2007, 11:49 PM
  #112
o damn, ok gotcha.
That was the original reason for this thread and my post, of course you can PM me about it. I'm pretty sure that the guide I wrote up covers it all, but I'm always willing to modify it if need be to make it more clear. I wish I had the pics for it so you could actually see it, not just read it.
Old 01-25-2007, 11:50 PM
  #113
distillion's Avatar
thanks guys, appreciate it!!!!
i may have missed in other posts but can you bump up the timing after this mod is done?
Old 01-25-2007, 11:53 PM
  #114
I would say YES you can. Not much though, maybe 1 or 2 degrees. I got like 1.5 degrees of extra timing outta mine (went from 15 to 16.5 degrees on pump gas)
Old 01-25-2007, 11:57 PM
  #115
distillion's Avatar
ok cool, but tuning is not neccessary for this mod though correct?
even with the significant drop of intake temps?
Old 01-25-2007, 11:59 PM
  #116
Tuning is not needed. You could optimize the tune for the lower temps, but I would rather leave it to allow you more room for heat soak. The bigger the gap from KR, the better IMO.
Old 01-26-2007, 12:01 AM
  #117
Yeah, you can leave it the same, it won't hurt anything.
  #118
distillion's Avatar
awesome info here guys!
i was gonna do the option B but thats just too much for me hahaha
Old 01-26-2007, 12:03 AM
  #119
That would help A LOT. The extra resevior tank would actually make a HUGE difference. I'm gonna do a resevior tank myself.... only it will be cooled with ice/dry ice
Old 01-26-2007, 12:15 AM
  #120
distillion's Avatar
yer car is gonna be the"coolest" car on this site hahaha
http://www.crateenginedepot.com/stor...P1702C196.aspx
http://www.crateenginedepot.com/stor...P1703C196.aspx
so jap says these come with the plate
did you guys have to use these or what, not sure what the deal is on them.
Old 01-26-2007, 12:19 AM
  #121
You can reuse them if they are not damaged. The first is one of the o-ring seals that goes between the endplate and the intake manifold. The other is the gasket that goes on the bypass valve. We just reused the stock ones, no big deal.
The top one surrounds the smooth machined face in this pic.
Old 01-26-2007, 12:23 AM
  #122
distillion's Avatar
this is finally starting to make sense to me lol
Old 01-26-2007, 12:29 AM
  #123
Here is the other gasket on the right.
Old 01-26-2007, 07:25 AM
  #124
distillion's Avatar
awesome
so then all i need is a hose and a y fitting and eventually my temps will drop a lil with my new found 2.7.
any tips on the best way to bleed the system?, also how thick/long of a hose should i use?
also regarding the pic that shows the cores, what is the BEST sequence in which they should be flipped.
Old 01-26-2007, 05:05 PM
  #125
awesome
You'll need 3/4" heater hose. I'd say about 4 feet just to be safe. Also bleeding the system is a long and tedious process, expect it to take several hours.
Quick Reply: Dual Pass intercooler
