"Knightmare" Build
Old 01-27-2013, 11:37 AM
klutch814's Avatar
yupp. well its on the site as like ecotec turbo down pipe. what about the bolts for this adapter? lol
Old 01-27-2013, 11:39 AM
Bad-A-SS's Avatar
I mean for 89 bucks I would hope that it would come with bolts lol
Old 01-27-2013, 11:43 AM
klutch814's Avatar
guess we'll find out hahaha
Old 01-27-2013, 11:47 AM
Bad-A-SS's Avatar
Im sure c130aviator would know the answer to it lol Maybe we should message him lol
Also my TTR Intake mani for ULWiz gets here tomorrow. Also a Hahn bov should be coming my way and a turbo shall be ordered mid week WOOHOO
Old 01-27-2013, 11:54 AM
klutch814's Avatar
whens it all going on?
Old 01-27-2013, 12:00 PM
Bad-A-SS's Avatar
Mid February and I need to get all my s/c parts gone too. Still contemplating if I should go with the PTE3431E or just stick with the PTE 5531E
Old 01-27-2013, 12:04 PM
klutch814's Avatar
hmm idk man. i got the 5431 billet. should do me just fine lol
Old 01-27-2013, 12:08 PM
Bad-A-SS's Avatar
What kind of power range and psi are you looking for on your built motor tho
Old 01-27-2013, 01:39 PM
klutch814's Avatar
i want 400whp. starting out at 20 psi and going from there
Old 01-28-2013, 12:02 AM
cmiller8006's Avatar
I would like to see a 5558. And go with a .63 ar turbine housing.
Old 01-28-2013, 12:11 AM
  #36
Bad-A-SS's Avatar
why go with the .63?
Old 01-28-2013, 01:13 AM
  #37
I say go with the .63 just because the spool isn't to bad. What will you be revving to? I think the .48 will be to restricting at higher rpms and cause the power to level off or fall.
Old 01-28-2013, 09:53 AM
  #38
Bad-A-SS's Avatar
I will be revving to 7200 just for safety until I do somethings to my engine like NBS, 78# or 82# valve springs, and whatever else I need to rev higher
Old 01-28-2013, 10:01 AM
  #39
rcarr0327's Avatar
i would gasket that adapter, still needs to create a seal between turbo and the adapter. you dont have a gasket for the actual v band though
Old 01-28-2013, 01:11 PM
  #40
Bad-A-SS's Avatar
Oh well ok then I'll add a 5 bolt gasket to the list along with topping of my Trans fluid, change my oil, make sure I have the grey sealer for my oil pan, and new spark plugs
Old 01-29-2013, 08:30 AM
  #41
Also why do a 5 bolt discharge? Just do a v band and be done with it. Dont fool around with the other stuff.
Old 01-29-2013, 10:27 AM
  #42
Bad-A-SS's Avatar
I am trying to, but I don't see where MAPerformance sells it with the .63 AR with V band tho??? Do you see it?
Old 01-29-2013, 10:33 AM
  #43
Bad-A-SS's Avatar
Woohooo Thanks ULWiz
My collection of beautiful turbo parts begins boys and girls
Old 01-29-2013, 11:58 AM
  #44
Bad-A-SS's Avatar
Nevermind Cmiller I talked to MAPerformance about it they fixed it for me. So they have the vband with .48 AR and .63 AR but with the 7200rpm redline would it be best for me to stick with the .48 AR or go with the .63 AR? Where are my turbo gurus
Old 01-29-2013, 05:52 PM
  #45
Are you going to raise the rev limit later? Theres prolly not going to be a big difference really
Old 01-29-2013, 05:53 PM
  #46
Bad-A-SS's Avatar
Probably will but not sure how long that will be away. So what are your thoughts Cmiller
Old 01-29-2013, 08:27 PM
  #47
c130aviator's Avatar
on stock motors 7200 is the limit.
On revving motors the following is needed to support each mod.
NBS or Neutral balance deletes from zeromotorsports
82# zzp valve springs, 330 shipped with titanium retainers on zzp ebay store
ati balancer, 440 bucks zzp or elsewhere
CAMS, get stage 2 from zzp or get a custom grind from comp cams 500-700 bucks
you are looking around 1700 bucks to do everything needed to rev, plus the count of tuning. I have done the first two mods, since I was in the block already, the other two I will do when I get the cash.
Old 01-29-2013, 08:34 PM
  #48
Bad-A-SS's Avatar
Yeah thanks man for clearing that up some more. So the next big purchase will probably be pistons, 82# zzp valve springs, nbs, and cams.
Old 01-29-2013, 09:53 PM
  #49
You need springs no matter what when applying more boost out of a bigger turbo.
Old 01-29-2013, 09:57 PM
  #50
Bad-A-SS's Avatar
Ok so what are you saying? That I should already purchase them?
Quick Reply: "Knightmare" Build
