"Knightmare" Build
Old 04-21-2013, 01:09 AM
  #126
c130aviator's Avatar
NICE! Love the hahn stuff, I am running the kit as well but with their turbo. TO all those hating on hahns pipes are so mislead. The full weight of the turbo kit is 60lbs, weighted it myself. The weight of the supercharger kit with m62 and all supporting parts weighs in at 100 lbs. Hahns kit is still lighter than the other guys slow supercharged car.
Great job man.
Bad-A-SS (04-11-2021)
Old 04-21-2013, 01:11 AM
  #127
Originally Posted by Bad-A-SS
Parts are here
More pics soon to come
sorry i didnt read back, what turbo and what manifold is that?
Old 04-21-2013, 01:31 AM
  #128
Bad-A-SS's Avatar
PT5558 and custom manifold from Hahn equipped with a turbosmart Comp40 WG on its gonna be so nasty
Old 04-21-2013, 01:32 AM
  #129
i want a 5862 with a .63 ar for my next turbo. What kind of power you wanting to make?
Old 04-21-2013, 01:35 AM
  #130
Bad-A-SS's Avatar
I am wanting to make about 400hp until the winter when I hope to build the engine and trans to support a hefty 500hp
Old 04-21-2013, 01:38 AM
  #131
if you do cams, really get the head breathing with a port job with a big exhaust you might squeeze out high 400's in our car when built. I want 500 whp next as well. Your turbo choice is interesting but I dont think our engine will get the 590 crank hp out of it. We are just too small in the CI area.
Old 04-21-2013, 01:41 AM
  #132
Bad-A-SS's Avatar
Yeah I kind of want to push this turbo to its wits end. I mean with cams, head pnp, pistons, sleeves, nbs or delete, and bigger fueling I would like to see what I could get out of her
Old 04-21-2013, 01:54 AM
  #133
i like the choice of turbo, really do. But when I can afford to move on from the 20g which i love btw, I am going to look at a pt58 or pt62, that way I can run lower boost and still make the power I am trying to achieve.
Old 04-21-2013, 01:58 AM
  #134
Bad-A-SS's Avatar
Yeah well if I figured it right your 20g moves about 47lbs a min at 22psi I think and my turbo should be around 47lbs a min at 18psi or so
Old 04-21-2013, 02:15 AM
  #135
I am dailying at 22 psi with very safe timing at 410whp. So you should get your 400 hp at about 18 psi, maybe. my head is CNC ported. exhausts make a big difference too, you want 400 you are going to have to go 3" all the way back.
Old 04-21-2013, 02:17 AM
  #136
Bad-A-SS's Avatar
Yeah I have been told this turbo probably doesn't wake up til about after 22psi
Old 04-21-2013, 11:35 AM
  #137
Bad-A-SS's Avatar
Here are some more pics of the parts that came in
Look at that big mouth lol
Old 04-21-2013, 11:39 AM
  #138
574
574's Avatar
mm mm mmm. I don't know sheitt about turbo set ups but everyone loves new parts!
Old 04-21-2013, 12:38 PM
  #139
Bad-A-SS's Avatar
Oh of course man lol install pics soon to come as I am getting ready to head off to work for the day.
Old 04-21-2013, 02:01 PM
  #140
love that manifold, get it and the hot side of the turbo powdercoated with ceramic. Its cheap and keeps the engine bay cooler.
My downpipe and o2 housing are separated, I see he welded those together on yours.
Old 04-21-2013, 02:20 PM
  #141
Bad-A-SS's Avatar
Yup and my front o2 is messed up from trying to get it out of the header so should I drill n weld a new one or just use existing bungs
Old 04-21-2013, 02:32 PM
  #142
get a new sensor and if the bung is messed up run to a local machinist and for 5 bucks he can retap it. Or just buy yourself a tap and do it yourself not bad at all.
Old 04-21-2013, 02:50 PM
  #143
Bad-A-SS's Avatar
No it was my old header n it's already sold. So just get a new front o2 then drill n weld a bung for my wideband? Behind or in front of the flex pipe? Also what did you use to put around the threads on your oil line n return line
Old 04-21-2013, 05:17 PM
  #144
Do you mean when I tapped the pan? I used a 3/8 npt with a wide ID to -12 or -14 an Its plenty big, cant remember, but on the threads of my return line? I just used plumbers tape and snugged her down. Its very strong. I dropped the axle on it and id didnt even flinch, its thin metal on the oil pan so you probably should weld in a block and bung but a tap is just fine in my opinion. Its strong.
I have a good used bank 1 sensor 1 laying around if you need it. I bought one when I was tuning my car as a trouble shooting step, turned out to be the tune.
Old 04-21-2013, 06:05 PM
  #145
Bad-A-SS's Avatar
Yeah I need one how much
Old 04-21-2013, 08:10 PM
  #146
IonNinja's Avatar
how much does a custom downpipe and manifold from Hahn cost over their off the shelf stuff?
Old 04-21-2013, 08:19 PM
  #147
Bad-A-SS's Avatar
I forgot but I will look at the quote when I get home. But I got a great deal since I got my quote when they did the20 percent off sale. Bill Hahn n I had a few personal talks on parts of the build and so forth. They have an lsj there that they mocked all the parts on until he was satisfied. I must say Hahn racecraft has THE BEST customer service and did anything basically to keep me happy thru the whole process.
Old 04-21-2013, 11:54 PM
  #148
I paid 70 at the dealer for my new one. But this one is used and has about 77000 miles on it but I confirmed it was working to the same spec as the 70 dollar ac delco one. Make me an offer or if you have something to trade let me know what you got. I love car audio and anything for our engines. If not just make me a fair offer. I would rather hook a brother up on here anyway. But trades are always fun.
Old 04-22-2013, 08:59 AM
  #149
Loner05's Avatar
I am confused did you mess up the bung on the old header or did you mess up the O2 sensor?
Old 04-22-2013, 09:30 AM
  #150
Bad-A-SS's Avatar
Just the o2 sensor threads I think if I have to do you want me to tap the bung on the header?
Quick Reply: "Knightmare" Build
