LE5 cam swap into LAP
Old 07-14-2011, 03:56 PM
ItalianJoe1's Avatar
Originally Posted by newt
There ya go then, buy some LE5 cams and you guys are good to go.
FYI all the non-VVT ecotecs have differant keys for the cam gears, so they probably won't work, my L61 uses a knotch as well as the LSJ I believe, the LE5 I have uses a pin and so would a LAP.
I'm trying to remember, but I believe you're correct on all of them. The non-vvt cars for sure have the offset keyway that only lets the cam gear go on in one position. I've done an LNF and one LE5, I thought they had a similar setup but i'm thinking now that I do remember a pin setup on one of them. I sold the LE5 gears/actuators/sensors, or i'd look at the spare set I have. Probably let them go too cheap, had a guy who needed a cam sensor and I gave him everything for $50, both cps, both actuators and both gears.
Old 07-14-2011, 05:21 PM
nhanson's Avatar
that means we could use aftermarket cams designed for the LE5
Old 07-14-2011, 05:28 PM
nhanson's Avatar
also who makes cams for the LE5 besides ZZP?
Old 07-15-2011, 06:15 AM
09LAP's Avatar
Jbp
Old 07-16-2011, 11:58 PM
FlyingLow's Avatar
LE5 cams do not work. Destroyed the head. Had the timing done from bottom up by the dealer after I put the cams in(vehicle was towed to dealer, was not started. Don't worry Im.not that dumb) and kaboom. Overlap is different. 16 bent valves, destroyed the seats, guides, and seals, and chipped 2 pistons. 3k **** up for a few hopeful hp.
Old 07-17-2011, 12:13 AM
09LAP's Avatar
*LAP thread deleted* srry for the loss bro...
Old 07-17-2011, 02:33 AM
You sure the timing was right? There's no way overlap causes that kind of damage. They should have at least tried to turn the engine over by hand before starting it, would have realized they did something wrong and avoided all that damage.
Old 07-17-2011, 02:35 AM
redcobalt07's Avatar
what kind of power gain does this mod produce?
Old 07-17-2011, 05:41 AM
09LAP's Avatar
im with joe here, they def should have done a "hand turn" first to ensure correct timing regardless if they knew they were different cams or not.
Old 07-17-2011, 05:45 AM
09LAP's Avatar
16 bent valves and 2 chiped pistons = the power of walking speed
Old 08-04-2011, 06:32 PM
  #36
Leafydialupking's Avatar
Will have to compare the timing gears between the two. I bet the timing marks are in different places.
Old 08-05-2011, 10:25 AM
  #37
newt's Avatar
Leafy - Both motors use the extact same timing gears and phasers, so I doubt its that.
This sounds like the motor wasn't timed properly, regardless of it being the done by the dealer or not, they can still make mistakes.
There is something weird going on here....
Old 08-05-2011, 10:33 AM
  #38
elecblue06's Avatar
Originally Posted by 09LAP
and yes you will most definitely need a tune with any larger cam, most likely you WILL need to upgrade your valve springs if you plan to take it over stock redline, plus the injectors start to suck ass around 7k anyways. Suggestion: supertech kit
great lulz will be had from this.. 1 2.2s' and 2.4's both have 24 lb injectors.. i ran with full bolt ons and a tune with a 7200 redline .. and didn't need new injectors..
2 the valve springs are the same on all models from what i remember ..
and i agree with leafy... something was seriously fucked up... if you destroyed all your valves and fucked up 2 pistons.. i highly doubt it was JUST the cams
Old 08-08-2011, 11:44 AM
  #39
09LAP's Avatar
very wheird newt
Old 08-08-2011, 11:49 AM
  #40
09LAP's Avatar
Talking
not even goin there...haha
Old 08-08-2011, 11:59 AM
  #41
elecblue06's Avatar
lol why not?
Old 08-08-2011, 12:34 PM
  #42
09LAP's Avatar
1. well stage III cams are going to shift that powerband up, starting at 3500 or so. to maximize the full range you'll have to have of course springs and shafts and a larger set of injectors the lift and duration of the valve puts a massive strain on stock injectors especially running 7500 and higher. you can do it with a 24# set and itll work fine till 7200 but to reach wherever your stage III's end (depending on cam) 7800-9000 your going to want those injectors
2. "the valve springs are the same on all models from what i remember .." where did that even come from? i mean im not one to play the "whose d**k is bigger game but when provoked come'on now
Old 08-08-2011, 02:53 PM
  #43
You seem to be confused. He has been talking about not needing new bits from just putting the LE5 stock cam into the LAP. Not about putting in a stage 3 cam.
Old 08-08-2011, 02:58 PM
  #44
elecblue06's Avatar
lol wut.. what does stg 3 have to do .. i swear this thread was about putting LE5 cams in an LAP.. which will NOT change the affective range that much
if you're using the LE5 cams you will not be revving to 7500 or higher.. i dont know what anything you brought up has to do with this thread.. and you said you need to upgrade your valve springs.. if you're running the le5 cams you dont
apparently i didn't post this previously but yes exactly what leafy said lol
Old 08-08-2011, 03:44 PM
  #45
09LAP's Avatar
Question
Originally Posted by 09lap
no you dont understand, we just wanna know if they fit. Personally im going to buy stage iii le5's if they do fit but i dont know wat flyinglow's plans for his are
wtf?
Old 08-08-2011, 03:50 PM
  #46
09LAP's Avatar
Flying low wants BIGGER cams, well since they sell nothing of the sort for our cars maby we could find out if they were the same cam since the head PN was the same....thus if the cams fit then low could use his choice of stage 1,2,3 cams
Old 08-08-2011, 03:52 PM
  #47
09LAP's Avatar
and as for this "which will NOT change the affective range that much" i agree they wouldnt but im pretty sure low was planning for something agressive
Old 08-08-2011, 04:00 PM
  #48
elecblue06's Avatar
there are really only one set of cams for the le5.. and the original post was about the le5 cams
and even then the one set of cams that are out there for the le5 you probably wouldn't need new injectors you probably wouldn't be pushing over 200 whp with them you could probably get 180.. which is still in the range of stock injectors. if you're revving over 7200 i'd recommend valve springs 7500 balance shafts
Old 08-09-2011, 09:35 PM
  #49
nhanson's Avatar
pretty sure everything will work its just that the OP or whoever tried it had something F-ed up when the swap happened.
Old 08-10-2011, 09:53 AM
  #50
FlyingLow's Avatar
I believe I had a sensor (either crank or cam) go bad and throw off the reference point. As for right now it runs like absolute garbage. Surges like bucking bronco at a stoplight, hold the rpms steady at 1500-2500 and you hear the thing misfire nonstop, and its down on power. Got my ass handed to me by a stock scion tc. And I have full bolt ons
. I'm about to just give up on this motor, throw a low miles boneyard motor in and sell the thing.
Quick Reply: LE5 cam swap into LAP
