LE5 cam swap into LAP
#51
I believe I had a sensor (either crank or cam) go bad and throw off the reference point. As for right now it runs like absolute garbage. Surges like bucking bronco at a stoplight, hold the rpms steady at 1500-2500 and you hear the thing misfire nonstop, and its down on power. Got my ass handed to me by a stock scion tc. And I have full bolt ons
. I'm about to just give up on this motor, throw a low miles boneyard motor in and sell the thing.
#52
#59
Flying low, are you now driving the car with "16 bent vales and nicked pistons" why is it running like ****?
the LAP is 10:1 vs the LE5's 10.4:1 so the piston to head height shouldn't be an issue, especially with the reduced stroke of the LAP (94.5vs98mm) we've already established that the head is the same P/N, so i would imagine everything would be the same, possibly even the cams, but im sure valves, springs and whatnot are.
So IMHO the timing was not set properly on Flying's car, as others have stated.
has anyone looked up the stock cam specs for both motors? i've been hunting for LAP stuff, but no luck
LE5
Bore - 86MM
Stroke - 98MM
Intake Cam
Duration - 210.3
Lift - .415
Exhaust Cam
Duration - 195.4
Lift - .395
LE5
Bore - 86MM
Stroke - 98MM
Intake Cam
Duration - 210.3
Lift - .415
Exhaust Cam
Duration - 195.4
Lift - .395
#60
LE5
Bore - 86MM
Stroke - 98MM
Intake Cam
Duration - 210.3
Lift - .415
Exhaust Cam
Duration - 195.4
Lift - .395
LE5
Bore - 86MM
Stroke - 98MM
Intake Cam
Duration - 210.3
Lift - .415
Exhaust Cam
Duration - 195.4
Lift - .395
#66
i think someone needs to just do it. from some evidence that has been floating around with part number and stuff i personally think it will work. i know from experience the 2.4 and 2.2 heads are interchangeable
#67
LE5
Bore - 86MM
Stroke - 98MM
Intake Cam
Duration - 210.3
Lift - .415
Exhaust Cam
Duration - 195.4
Lift - .395
LE5
Bore - 86MM
Stroke - 98MM
Intake Cam
Duration - 210.3
Lift - .415
Exhaust Cam
Duration - 195.4
Lift - .395
ThoR294
10-04-2015 08:44 PM
