lsj air to air problem
#51
I remember about 2 months ago I made a thread about this and everyone said FAIL FAIL FAIL... haha awesome to see the setup in action. Can't wait for the results.
#52
And what do you mean hot coolant. You're such a noob it isn't even funny.
you're correct, but adding things like dual-pass opt b and another heat exchanger minimizes those losses
#53
the problem i see in the stock setup is that theengine i have will flow way more than it can handle. instead of making a single pass and adding coolant tanks and heat exchangers to a system that is not a good design to begin with. i opened everything up, let the air go through everything smoothly and the end result is less bunched up hot air that has too many restrictions as it is, to something that air will flow through alot easier and will create less heat just for that reason. and also will flow alot better with the tvs and other mods
#54
no, no you're not
agreed. it's fact. i think that for the lack of room that gm had in the design of this engine, it's an adequate design. could it have been more efficient? hell yeah, but it would probably have cost way more in r&d $. dual-brick style like on the zr1 costs a pretty penny
lol... the idea is to prevent the coolant from getting hot... i.e. heat exchanger/dual-pass.
#56
With that said, you might want to watch out who you call a ******* noob to. I have a fully built, self fabricated, and self assembled air-to-air intercooled turbo Integra sitting in the garage right next to my Cobalt which was a fore runner for testing the Lysholm 1200AX twinscrew on it amongst a lot of other mods way before most on here tried anything original or the TVS was even thought of. I do all my own work and tuning, and have a lot of time under the hoods of some proven fast cars, and have done my part to contribute to the Cobalt community amongst others.
Lastly, lets see what the OP can do with this setup since it's and original design and a step foward in innovation to something possibly better than what is available now.
#58
like 2k5 ss/sc said you could easily take out the air to air in place for a water to air like zzp did for the 2.4 turbo setup .. really it's getting a new intake manifold / modding the stock manifold to work with piping then finding the best setup .. it could be CYRO water to air or what ever have you or an air to air with custom FMIC sprayer no one knows yet but the stock manifold gutted is a good first step
#59
Yes, if there is a way to cool the coolant in the air to water setup sufficiently it will be far superior to ambient temps passing through and air to air setup. An ice chilled or cryo chilled setup could significantly do so, however we still have the issue of the intake manifold being very restrictive in its flow capabilities. Cramming air into a spot where it can not go any where causes turbulance which in return causes a lot of excess heat. This heat will kill power, which will even overcome your coolant mods at a certain point. Thus, a properly designed intake manifold that will flow far superior to the stock one even with a front mount air to air and will be way better. Heck, if you were hell bent you could use an intercooler like the vortech superchargers have to reduce pipe length and keep the air to water setup in conjunction with the better intake manifold.
#60
If people cannot see the benefits of swapping to something like this then they need to start doing some research. The TVS flows enough CFM's to surpass what the stock intake manifold can cool effectively and still pass air into the engine. GM had a great design, but a better flowing IM will help out tremendously if you have actually seen the ports that the air is crammed through.
The stock IM manifold for the LSJ is a great design. To get it to work better with a TVS or Tubro you should get the ports to the laminova cores ported. OTTP can help you out with that.
The water/air setup in the LSJ IM is far more efficient then an air to air setup. Superchargers create more heat then turbos. So turbos don't need as efficient cooling systems.
#61
#62
Because the Intake Manifold is not an issue with the M62. And a company has address this issue for larger power adders.
This is probably true.
The laminovas need to go and a very large water to air brick needs to be added, along with an intake plenum and equal length runners...
Porting the stock manifold is just not enough for fully pushed tvs build...
#63
There is room from improvement with larger ports.
I actually ran a ported IM for a few weeks. My IAT2s were lower and climbed slower during a WOT run.
The ports need to be just large enough to flow the amount of CFM from the TVS. Basically all four inlet ports for the laminova cores combined need to be the same size as the outlet of the TVS.
There is plenty of room in the stock IM to accomplish this.
Turbo guys need to stop trying to apply their knowledge to superchagers...
What is the called when the boost backs up and re-enters the supercharger? That is probably happening to this car.
For all the turbo guys...
This is like installing 2" charged air pipes on a turbo with a 3" outlet.
#64
4in would be nice but not needed. if you all think the stock setup will run this fine then these pipes and that intercooler will be perfectly fine even overkill.
but like i said we will see this week. the tuner i use cant do anything for a few weeks so im gonna go to another guy hopefully by the end of the week
#67
I bet you could fit a 3" round pipe in the outlet of the TVS no problem. And there will be plenty of space all the way around. Idk. You guys can think what you want. I'll measure the outlet on my TVS this week and report back to this thread. I am interested to see how big the ports in the stock IM need to be opened up to match the outlet of the harrop.
#68
You are not running a turbo.
as for piping size, 3" is a lot more practical. That's almost half the volume as using a 4"
#69
You can build and fabricate anything you want, that doesn't mean you posses knowledge in certain areas of a build. The point that you stated hot coolant flows into the intake manifold which kills cooling. Most people know that the heat exchanger does a sufficient enough job removing heat from the coolant. So infact the coolant flowing back into the intercooler is in fact cooled and not heated. Then why do the IAT's increase? The main cause being the air so hot the water has to take on the extra heat but doesn't stay long enough in the small intercooler they provide in the factory manifold to remove all of the excess heat.
You still haven't even begun to get into how restrictive the stock intake manifold is, and its direct contribution to the reason why this whole project was started. Nevermind the small exhaust ports on the head that will back up the airflow even further down the road. You can only cram so much air into a place before it becomes counterproductive. We can continue this pissing contest if you want, but I am very familiar with this car, its attributes, and how to properly setup/tune it.
I am done with my inputs on this as it's distracting and infringing on the OP's main purpose of the thread. I will be checking back however to see how this all work out, and I wish the OP the best of luck with it.
#71
what a **** show.
novel idea, massively nasty execution.
take the flow rate @ the PR you want to run and match that up with pipe sizing, my initial numbers come out to about ~1.68in of cross section with the SC at max eff% flow/pr.
this is not a turbo, thus its flow rate is no where in that neighborhood. no need for 2.5in piping, so dropping pipe size will help control the MUCH larger PD your getting across that rats nest of pipe and couplers.
the internal flow area of your system is HUGE, 7* of bend = 1ft
its times like these you need to look at the well done street-minded turbo set ups of the world, notice how short and direct they run the charge pipe, notice how the IC is just the size needed for the flow rate.
things like this will take this idea from its current disaster and turn it into something worthwhile.
#72
These pipes should be at least 4". The air to air Intercooler should have a larger inlet and outlet. Ideally you would want them the same size as the TVS outlet. You are choking the TVS within the first few inches.
Not only are the 2.5 in pipes sufficient but I bet they are over kill.
#73
its either gonna be fred at smg, or dentsport.
and i know the pipes are not perfect. they arent meant to be. as soon as i know the system works ill be getting custom pipes solid all the way around made. the intercooler is fine. its wide and flows great. all i can say is wait and see.
but please dont stop posting, i love seeing and learning as much as possible
#74
