LSJ Build Meets BW EFR 7670
Hey guys i figured i would post my build over here. I have it posted on j-body but figured since it is using a LSJ/LAP as the power plant i would post it over here as well hope you dont mind.
Build List
LAP Block
LSJ Crank
Pauter Rods
JE Pistons
Injector Dynamics 1000cc
Racetronix Fuel Pump
Griffin Universal Radiator
Treadstone FMIC
Custom Intake and Turbo Manifolds
Borg Warner EFR 7670 Turbo
Haltech Sprint 500 Standalone
Bully Stage 4 Clutch
ZZP LSJ Phenolic Spacer
OBX LSD
LS1 Throttlebody
Hardened Oil Gears
Balance Shaft Delete
Stage 3 Cams
Ported LSJ Head
Supertech 78# Valvesprings
Build List
LAP Block
LSJ Crank
Pauter Rods
JE Pistons
Treadstone FMIC
OBX LSD
LS1 Throttlebody
Hardened Oil Gears
Stage 3 Cams
Ported LSJ Head
i have the bottom end put together but im too lazy to put the pics on my computer and gonna start the crappy job of rewiring the car for the haltech 500. but the good news is i already had the car gutted so it should be a lil easier lol
oh and since i didnt say it earlier this is all going into a Sunfire
The 4 puck act with the stock pressure plate should hold that. For more protection I would get your local custom clutch shop to make you a stiffer pressure plate and run either the 6 or 4 puck depending on how much they can increase the clamping force.
