| Forum Jump | Gallery | Social Groups | VBgarage | Videos | Chat | Link To Us | Decals | Site Map | Contact Us |
| ADVANCED Performance Modifications For advanced modification topics only. |
This is a discussion on OFFICIAL Blown 4-banger build updates! within the ADVANCED Performance Modifications forums, part of the Engine Technical Discussion category; Ok since I've been getting A LOT of PMs asking for updates on my build, I decided to make a ...
LinkBack | Thread Tools | Search this Thread | Display Modes |
#1 | ||
__________________
SOLD ![]() In its future: SR20DET/COILOVERS/DRIFTING |
#2 |
cant wait man thats going to be sick
__________________
![]() ![]() 2007 SS/SC Mods: Stage II, Port & Polished blower, GMPP Touring Exhaust, GMPP slotted and drilled rotors, DC Sports 4-1 Ceramic Coated Header, Ingen CAI (Black), TTR Poly Engine and Tranny Mounts, Random Technology Down pipe |
#3 |
$0.00
Sponsorship FTMFW!!! CP said they would be like $700-$750 with the coating.
__________________
#4 | |
Quote:
how do you go about getting sponsored
__________________
#5 |
Well, with me, its through some connections with my dads company. Labor will cost me nothing, since I work at an engine building shop I have access to all the machines I would ever need.
__________________
#6 |
alright thanks good luck with the build
__________________
#7 |
Awesome dood, keep us posted!
#8 |
SSCharged
dam dude thats good news, what is teh difference between forged pistons and regulars? sorry big time noob question
__________________
![]() Sponsered By: Dream Toyz Ossining Fire Dept. Holla Hose Co. 5 Engine 100!! |
#9 |
They are forged they just have coatings on the sides and top, helps with longevity and makes them slide better!
#10 | |
Quote:
Forged pistons are made by heating the aluminum solid cylinder to about 800*F, then uses a huge press with like 20 tons of force to press a form into the cylinder forming the shape of the piston. This is a far better process, makes a much stonger piston, and when it gets too hot, it melts, saving internal parts from flying chunks of piston. However it is more expensive to make.
__________________
#11 |
theres also a negativ ehtough....forged pistons are also heavier than cast iron pistons, and thus are not as well suited to high revving, but most tuners find this a very easy sacrifice to make, as few people like making power by revving to 12kRPMs....besides hondas of course
__________________
Barbados Blue Metallic '04 GTO M6 | Kooks Signature Series Long Tube headers
Black '06 Cobalt LS Auto: Supercharged 265 bHP | GMPP Exhaust | Smoked Taillights | 5% rear, 15% front | Black Projectors | 18x8 Black Kyowa rims | Nexen P3000 tires | Auto Transmission Mounts | Koni Front/Rear Struts | Sportlines | 10k low/6k high beams | ZZP Mid-Length Header/DP combo | AEM UEGO | Black/Red Insert SS Seats, Door Panels, and Trim Pieces | High Rise Spoiler | M62 Blower | ZZP Heat Exchanger | Option B | Red Mech. Boost Gauge | Dual Red Interceptors | TTR Rear Sway Bar | |
#12 |
It's easy to get sponsored when your dad runs at Car TV show and a Magazine :-P Cameron get's lots of favors and freebies!
__________________
Tuner of 2.2L, 2.4L, 2.0L S/C, 2.0L T/C Cobalts, and Ford Mustangs
#13 |
did they give u a part number........ once I get to this point in time I would like to order some high quality internals. Have you found any sources for rods yet?
#14 | |
Quote:
__________________
2005 Black Cobalt SS Supercharged
#15 |
X2^^^
No new updates so far. The freakin guy from COMP who was doin my cams went on vaction until the june 13th ![]() The guy from Ferrea is basically wating for cam specs so he can send off the valvetrain. Pistons are still being made, they have about 3 weeks to go.
__________________
#16 |
you shud put a turbonator en et
But seriously, can't wait to see the outcome of this build. Good luck!
__________________
#17 |
has a Snobalt and a
This will be an awesome build. Why not the 10:1 compression pistons? Is the 9.5:1 better for a higher HP setups?
Another noobish question, what about the diamond head pistons, I was told that they were better than forged. |
#18 |
92mm pistons @ 8.0:1 compression.
EVO stage cam (the same profile) Ti valve train port the head neutral balance shafts get the cometic head gasket of course, get a good performance crank and rods.....that'll leave more than a few cars in the dust
__________________
#19 |
since hes being given everything daddy wants and skipped the real answer, ive looked into it ill tell you. you have to go to shows already and win several of them on your own or at least place well. you have to show that you can get from show to show and let people see the car and their parts on it. you dont even get much of a discount at the lower levels. something like 10% of tires once a year when i looked into nitto. and you have to put a banner going across the top of the windshield.
__________________
"That sound behind me is the sound of money exploding" Jeremy Clarkson in a Murcielago
#20 |
Diamond is a brand of piston. You don't actually make the pistons out of diamond.
__________________
#21 | |
Quote:
It is new Bling Bling for your motor. The block should be cast out of 24k gold too.
__________________
2007 SS/SC G85
The best one yet!!! TOP SECRET!!!![]() |
#22 |
Ahh good blown. You can come over and help me install my SRP's when they come in.
#23 | |
Quote:
The 10:1 will make more power than the 9.5:1 at the track, but will have to be so detunes for the street that the 9.5:1 will be faster on pump gas. We had the Banana maxed out at ~430bhp on the Aeroforce scan guage with the 10:1 pistons and 109 Octane. On pump gas it reads 280bhp, which is worse than it was on the 9.5:1 ratio.
__________________
#24 |
Seems like you finally got la bananna runnin
__________________
#25 | |
has a Snobalt and a
<------ Ultra Noob
Quote:
So, what compression ratio be better for compression that would run well with an y FI product (turbo, twinscrew, roots, etc)?
__________________
| Bookmarks |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Official Procharger Build Thread | chevytech007 | 2.0L LSJ Performance Tech | 1100 | 09-11-2008 06:48 PM |
| Build book for 2.0 SC from GM coming (not soon) | victory_red_SS | 2.0L LSJ Performance Tech | 17 | 02-26-2008 05:43 PM |
| The official FullThrottle build thread | MVP | 2.4L LE5 Performance Tech | 23 | 12-04-2007 03:21 AM |
| Official Twin Screw build | Mase | 2.0L LSJ Performance Tech | 330 | 09-14-2007 03:47 PM |
| Sticky **GM Racing Releases New Sport Compact Performance Build Book | Snowman | 2.0L LSJ Performance Tech | 0 | 05-21-2005 09:53 PM |
