OFFICIAL Blown 4-banger build updates!
Old 07-20-2007, 05:25 AM
  #176
WSFrazier's Avatar
Trust me, no cam sensor will get very annoying after a couple months.
WSFrazier is offline
Old 07-20-2007, 05:33 AM
  #177
Asphalt Assault's Avatar
Originally Posted by Onyxd04Redline
People still buy **** from JBP? Do you like getting ripped off?
They do charge alot for some stuff. there header for instance is a work of art. I thought of getting it but soon realized for the more power I obtain for price for 5 hp was not worth it to me.
Originally Posted by WSFrazier
^^^ Exactly my point, JBP is out of the question. I don't see how they are the only ones that can produce these blanks.
THey dont produce blanks. they get them from GM for the LSJ. you get to keep your old cams.
I am not calling you guys wrong. I am just saying in our search, we came up blank. GMMP even told us they won't give out any information for LSJ blanks, or anything about their Comp grind in the build book.
If you know how to go about getting LSJ cam blanks for GM, please let us know. If JBP is the only magical way... well then I personally won't trust them, but that is just me.
JBP gets the part as easily as you can. If you cant trust them then go else where.
From LSJ build book: "The factory camshafts have been replaced
with performance cams from Comp Cams. The
intake cam needs to go in the engine first.
The Comp intake cam has the following
specs: 0.441 inch net lift with 218 degree
valve duration at 0.050 inch lift on 109
degree lobe separation.""The Comp exhaust cam specs are 0.437-inch
net lift with 220-degree valve duration at
0.050-inch lift on 109-degree lobe separation."
http://tunersource.gmblogs.com/Racer...LSJ_Chap_6.pdf
See page 113 and 114
GM PART # 88958611
GM PART # 88958612
found at http://www.gmpartsdirect.com/results...ges=1&pkgid=92
cam spec sheet from gm
http://www.crateenginedepot.com/store/PDFS/ECS.pdf
more cam blanks and performance cams from gm
http://www.crateenginedepot.com/stor...afts-C141.aspx
Asphalt Assault is offline
Old 07-20-2007, 11:22 AM
  #178
Onyxd04Redline's Avatar
What are the stock cam specs again? I think going to just a hotter exhaust cam profile would be better then going with brand new cams. Our intake cam provide's us with decent low end power so a hotter exhaust cam will just give us a better defined top end.
Onyxd04Redline is offline
Old 07-20-2007, 01:17 PM
  #179
Blown 4-banger's Avatar
GM PART # 88958611
GM PART # 88958612
Those are L61 cam blanks bro. I bought them and had them IN HAND. I returned them and just decided to regrind the stockers.
Blown 4-banger is offline
Old 07-20-2007, 01:41 PM
  #180
WSFrazier's Avatar
So no one has yet showed us where to get GM LSJ cam blanks.
Old 07-20-2007, 01:55 PM
  #181
Supposedly a guy from the parts department of the dealer I got my blanks from, found a "secret" part number for LSJ blanks, and ordered them. Hopefully they are the real things.
Old 07-23-2007, 06:09 PM
  #182
THey are blanks? and L61 cams are interchangble with LSJ so I did not understand what would be the problem? your getting them ground. They are on the website for the LSJ I thought.
In the build book they describe going to comp cams for performance cams.
Maybe ask Comp Cams or Crate Engine Depot.
Heres the info. I provided on a spec sheet. I did not realize at the time that the cam sensor would not work. but they do physically fit. So it made sense to me if they fit you could grind to what ever timing you want.
�� The 2006MY L61 cams can interchange with LSJ cams, both intake and exhaust. These cams are
the exact same profile, only at different timings.
The 2006MY L61 timings are 116 intake, -103
exhaust. The LSJ timings are 100 intake, -115 exhaust.
�� The LNF and LE5 exhaust cams could interchange. The LNF and LE5 cams are not interchangeable
in any other way or with any other ECOtec cams.
Valve springs are the same across all variants, and should be upgraded for high-rpm operation or
increased lift.
The GM Performance Parts ECOtec cam set (88958648 set or 88958636/7 individually) is an aggressive
race cam
. They are not stock-replacement cams; they require upgraded valve springs and retainers.
These cams were designed for a race motor, using the ‘06 L61 as the starting point. The cams will not fit
the 2.4L LE5 head and will not work with the stock ECM or lifters. They physically fit the 2.0L LSJ head,
but the vacuum pump / cam sensor will not work in a stock engine.
SO the question is from Comp Cams or JBP or any other producer of performance cams, do they have the timing sensors in the cams? and if not how does it work with out it?
Old 07-23-2007, 07:17 PM
  #183
SSdan's Avatar
THey are blanks? and L61 cams are interchangble with LSJ so what would be the problem? your getting them ground. I am not sure what the problem is here. they are on the website for the LSJ.
Maybe ask engine crate depot.
The camshaft position sensor doesn't work with the L61 cams. The car would still start but it will take more cranks due to the PCM not knowing the position of the cams during ignition.
SSdan is offline
Old 07-23-2007, 09:16 PM
  #184
Exactly, and my cars driveablility will be out the window with the cams, and I don't need an extra thing to make it a pain in the ass.
Old 07-23-2007, 09:38 PM
  #185
WSFrazier's Avatar
Actually, WOP said something on RLFs about an oil valley that prevents us from using the L61 cams. And we verified this when doing cam swaps on our LSJs. You would need to somehow block that valley where our cam sensor would be IIRC.
Old 07-23-2007, 09:59 PM
  #186
according to cam spec sheet that they are interchangeable though?
Old 07-23-2007, 10:24 PM
  #187
Well aparently thats wrong
Old 07-23-2007, 10:27 PM
  #188
Witt's Avatar
Physically they can be if you plug an oil supply near the LSJ cam sensor. However, as the spec sheet mentions, it will not work with the stock engine management system.
Witt is offline
Old 07-24-2007, 04:06 PM
  #189
SwizzDSMSS's Avatar
I think the only way to go is custom.
SwizzDSMSS is offline
Old 07-24-2007, 05:42 PM
  #190
elvisc's Avatar
use a standalone and yay problems gone
elvisc is offline
Old 07-24-2007, 08:47 PM
  #191
I would, but unfortunatly, I don't have $2500 for a standalone.
Old 07-24-2007, 08:57 PM
  #192
LSX RWD S/C conversion
victory_red_SS's Avatar
Then you likely wouldn't want to spend the money for the blank LSJ billet cams.
Also considering that JBP is the only place you will find these, you likely wouldn't buy them anyways.
victory_red_SS is offline
Old 07-24-2007, 09:22 PM
  #193
sunfirejoe's Avatar
sow hat happened of the secret part number, can u give ti out
sunfirejoe is offline
Old 07-25-2007, 12:18 AM
  #194
Doc
Doc's Avatar
Intake Cam Part #12589355BA
Exhaust Cam Part #12589340BA
I forget where I got those numbers....maybe they work.
Doc is offline
Old 07-25-2007, 12:46 AM
  #195
Go JBP then and get the grind of stock units. Oh and a local news paper here "The WInnipeg Free Press" did a FREE PRESS TUNER CAR #3. the car of choice the cobalt SS/SC. they did custom cams and retained full warranty for the full build. they also made it wingless . so I would think if a newspaper with GM Dealer help is able to can get cams then you can....LOL.
Old 07-25-2007, 02:18 AM
  #196
Cobalt_Supercharged's Avatar
He is getting a regrind on the stock cams from Crane Cams.
Cobalt_Supercharged is offline
Old 07-25-2007, 02:40 AM
  #197
Thats great. I expect he will have great results.
Old 07-25-2007, 02:47 AM
  #198
Not trying to be a dick or anything, but were you being sarcastic?
Old 07-25-2007, 03:10 AM
  #199
sunfirejoe's Avatar
lol i say he was, get him
Old 07-26-2007, 06:00 PM
  #200
Those are the stock intake and a exhaust cams (not blanks) for the LNF 2.0L Turbo.
Quick Reply: OFFICIAL Blown 4-banger build updates!
