Official Gen III Block Thread
#51
Theres a main oil galley plug right under the oil filter and this galley also goes to the head where there is another plug . If your turbo you can run the line to a trans or power steering cooler and then right to the turbo. No 4AN line is perfect size
I used a Ford power steering cooler. You can run bigger fittings if your using it as a cooler only or put a T in it for the turbo. no 6 or 8 would work in that case.
#53
The entire set up is a 2.0 LDK engine. ZZP just takes the crank out and modifies the reluctor wheel so it will work with the LSJ. The motor is a direct drop in for an SS/TC. That pic I posted of the oil cooler ZZP sent with the motor. It was a direct bolt on. I just had to run a custom length coolant hose because as you can see in the pic one fitting on the cooler faces the wrong way.
#59
the crank relucter I believe is the same read through this there is a guy with a lsj crank in a l61 block https://www.cobaltss.net/forums/2-0l...builds-292623/
#60
e67 pcm from gen 3 2.4, we need the LSJ reluctor clocked to match the 2.4 reluctor wheel because the 2.4 wheel doesnt mount to the 2.0 crank shaft
I havent tested this personally, only from what I have read.
the E67 is shared with the Corvette and therefore has more support than the p12 that is attached to the LSJ
#61
#66
Why would u not drill and tap the holes that hold the oil cooler on there's already spots for them in the block then just drill the 2 holes for the oil to pass from the oil filter housing to the oil cooler
#68
-4 lines are too small for an oil cooler.
Adding a stock oil cooler is a waste as well. I don't think you realize how involved it really is. You have to also add a press in bung to one of the holes. I've done this before for a guy and what a waste of time for something that doesn't add much benefit. Doing like what Mr b said will be easier then trying to add a stock one.
#69
Its not for an oil cooler, anyway for 2.1 guys with no oil feeds I had this guy fab this part and it works amazing.
http://www.ebay.com/itm/181848046066?item=181848046066&viewitem&vxp=mtr
#71
Ecotec Oil Pressure Sender Tee 4 Cylinder GM | eBay
I have a 2.1 build, gen 3 2.4 block that killed 2 turbos from 0 oil pressure, when using the oil galley port on the filter housing. Engine is currently out and still pondering about a turbo feed port on the block. Anyone with the 2.4 block have any solutions?
