Remote oil filter/cooler
Might not be much interest to most, but I got my remote oil cooler/ oil filler kit this week. Replaces the coolant cooled oil cooler and bypasses the filter for a spin on version. Kit was made by www.unique-fabricating.com for my Ariel Atom.
The adapter for the filter boss might be of interest to someone. has a port to attach the original oil pressure sensor and a separate one that is 1/8 npt to fit an autometer oil pressure sending unit.
So 6Ltrs total right? Sorry I'm kinda new to this stuff. I want to do all my best possible supporting mods for stg2 next month, and this looks like a positive cooling method. How are our S/C cooled?
the sc is cooled by a totally different cooling than system than the engine coolant, i believe it uses air to liquid cooling, the charged air passes over 4 "cores" which have fluid running through them and cools the IAT2 temp to prevent kr.
A front mount heat exchanger is usually recomended for a stage 2 setup, might as well grab you an option b also, i just installed mine the other day and it was a pain in the ass but the temps are def lower than without the unit.
not sure how many liters the car takes, i know it takes 6 quarts of oil normally.
Not sure where your going to mount that oil cooler radiator, but if you get fmhe it pretty much takes up the hole front end.
One thing to keep in mind about the oil-to-coolant coolers like what is used stock is that besides helping to keep oil temps down they also help get the oil up to temp faster. The coolant can get up to normal range pretty quick but on a car without a oil-to-coolant cooler if you watch oil pressure it can take quite a bit longer for it to start warming up enough to fall to normal operating range.
If you live in a southern state where it is warm all year it probably won't be an issue, but if you put a larger oil-to-air cooler on the car and completely remove or not use the factory oil-to-coolant heat exchanger you might consider adding or getting a oil-to-air model that has a thermostatically controlled flow. That way the oil can get up to normal operating temp quicker (although not as fast as an oil-to-coolant setup) which will minimize wear and not cause the oil pressure to remain high and bypass the filter.
Thanks, good thoughts. This will be in an Atom that sees only summer driving and I have a 2 liter oil pre-lube/accumulator installed as well.
You should be good to go then if you warm it up well before any spirited driving. An oil temp and pressure gauge might come in helpful just to make sure everything is warmed up and flowing.
So, from the factory my car has a heat exchanger somewhere? Am I to assume that this device works as an intercooler for the s/c? If this is the case, then why hasnt anyone developed an intercooler to mount under the charger?
Yes, the car comes with stock h/e but its pretty small and its fine for stock use, but when you start pullying down the iat2's start going way up and you will get kr and blow you **** up or just loose allot of power from it cause the car will pull timing.
The factory h/e is located in front of the radiator, if you look down under your hood you will see a thin radiator looking thing with a bolt in the top left corner, thats your factory h/e.
This is talking about the lubrication system oil-to-coolant cooler, which stock also happens to be a heat exchanger. It is the device that is attached to the side of the oil cartridge filter housing and has an engine coolant feed and return lines that run to and from it. Approximately a quarter of an engine's heat it generates from the combustion process is transferred to the oil (with the majority of the rest transferred to the engine coolant). The stock oil-to-coolant heat exchanger transfers this heat to the engine coolant which in turns flows through the radiator where it is passed to the ambient air flowing through it.
The intercooler system on the supercharged LSJ cars uses a liquid-to-air intercooler core to absorb heat from the intake charge and then passes this heat to the coolant-to-air heat exchanger (i.e. the small front mount radiator) but this is a different exchanger than what is being discussed here.
id hate to dig up a thread from 2009 but im in a pickle here with my oil cooler on my Le5, damn thing was leaking dunno if its cracked or the orings were shot, and i wanted to bypass it, didnt see this plate listed on their website as being available to purchase at all.
LNF Cooler Plates
I actually made up my own plate for my LNF as I couldn't find them for sale. I purchased a cooler, milled it down and welded 2 -10AN fittings on there. If anyone needs plates fabricated I could probably whip up a few. Send me a message at info@corsomotors.com
importkiller
09-30-2015 07:18 PM
