Color matched SPRAY PAINT from GM!
Old 10-24-2006, 08:48 AM
Jackalope's Avatar
I no longer work for GM and can't get part numbers anymore.
Heres all the colors for our cars and the spray can part #'s so you can order them from any GM dealer.
BLACK (41U).............................12345119
OLYMPIC WHITE (50U)...............12345205
VICTORY RED (74U)..................12345539
YELLOW (34U)...........................12346642
LT TRNISH SILVER (67U)...........12346694
CASMERE MT (15U)...................12346726
EMERALD JEWEL MET (38U)........12346798
LASER BLUE MET (21U)..............12346786
SUNBURST ORANGE MET (56U)...12346722
ARRIVAL BLUE MET (91U)...........12346648
MAJESTIC AMETHYST MET (84U)..12346219
ULTRA SILVER MET (95U)............12345305
PACE BLUE (20U).......................88860746
SPORT RED MET (29U)................12346746
Now these are the color names but I would STRONGLY suggest you double check your paint code against the (--U) next to the color to be sure you ask for and order the CORRECT color! GM does change names but paint codes never change, always go by the paint code even if it has a different name. Again paint names can change from year to year and model to model but paint CODES DO NOT!
Note: these are 5oz. cans of color matched paint from GM, not aftermarket! These are the absolute closest you will ever get to matching your cars color.
Any questions?
Old 10-24-2006, 08:52 AM
Tofu's Avatar
Wow that's pretty cool. How does application work? Is it the same prepping process as touch up paint or do you just spray it on in a few coats?
Old 10-24-2006, 08:53 AM
Jackalope's Avatar
Just like regular spray paint works.
Old 10-24-2006, 08:55 AM
mkulrey13's Avatar
hmm pace blue...anyone seen a cobalt that color?
Old 10-24-2006, 09:04 AM
D4u2s0t's Avatar
i have a question... why does nobody have my color!
Old 10-24-2006, 09:14 AM
splink's Avatar
is there a clear coat color we should use?
[noob to painting cars...]
Jackalope's Avatar
Whats your VIN#? I'll see what I can find.
Old 10-24-2006, 09:15 AM
johnkb8's Avatar
2008 or 2009 they will prob have this color on Cobalts
Old 10-24-2006, 09:17 AM
Coblt ss super's Avatar
How much is it for 1 spray can?
Old 10-24-2006, 09:18 AM
johnkb8's Avatar
$5.36 @ gmpartsdirect.com
Old 10-24-2006, 09:20 AM
splink's Avatar
where is the paint code on our vehicles? i know they like to change locations for fun!
Old 10-24-2006, 09:22 AM
its i think under ur floor in the truck its a sticker on the left to the spare jsut lift up the floor as your going to get the spare and look on metal to the left and theres a white sticker its on there
Old 10-24-2006, 09:24 AM
splink's Avatar
i have seen that sticker, will check it out, and will have to pick up a can for the just in case
Old 10-24-2006, 09:32 AM
Jackalope's Avatar
Pace Blue is an 07 color. No I have not seen one in person yet.
Clear coating would be up to you and what you are doing.
Old 10-24-2006, 09:50 AM
forced_induction's Avatar
wow thats great, i just got a nasty chip in my paint. gonna order some victory red now
Old 10-24-2006, 10:00 AM
BravoPuma6's Avatar
good info to know! Is this regular spray paint or can it hold some heat?
Old 10-24-2006, 10:18 AM
Jackalope's Avatar
Well I personaly use it to color match my calipers to the car and also to paint trim parts under the hood and I've never had a single problem with it.
My old Cavi had the calipers painted for 3 years with no issues either. The Cavi also had a painted intake manifold and coil pack cover too, no problems there either.
I'd have to say it can hadle heat just fine.
Old 10-24-2006, 10:20 AM
GTP
GTP's Avatar
subscribing
Old 10-24-2006, 10:22 AM
splink's Avatar
sweet...i may have to paint my calipers now that there is a color to match it...jackalope, what all did you use/do to do your calipers with this paint?
Old 10-24-2006, 10:27 AM
BravoPuma6's Avatar
very reasurring, thanks!
Old 10-24-2006, 10:28 AM
Jackalope's Avatar
Cleaned them with Brak-Clean let them air dry, sprayed them with paint. I covered the rotor with an old plastic bag so it wouldn't get any over spray on them. I use the whole
5oz can to do all 4 calipers making many light coats so it looks better. Lots of light coats look way better then a couple thick ones.
Old 10-24-2006, 10:29 AM
Jackalope's Avatar
No prob!
Old 10-24-2006, 11:09 AM
IMADreamer's Avatar
I don't want to dispute Jackalope because he is a great asset to this community but I used GM color matched paint to do my fuel rail cover and after a month I started getting tiny bubbles in the paint. I think this holds up to heat reasonably well but when exposed to it over a long period of time it starts to bubble. I say this because I noticed it after I made a three hour drive and I think the long exposure to the heat got to it. I have now switched to a duplicolor product that matches extremely well and I have had no problems. I don't have pictures yet but I will post them up sometime.
Old 10-24-2006, 11:16 AM
Jackalope's Avatar
Hmm, thats odd. I did the engine parts on my old Cavi and it held up till the day I traded it in, the new owner has showed me the car since then and the coil cover plate part was still fine, TONS of heat there sitting on top and inside of the valve cover. Same with the intake manifold, you know the ugly black plastic part between the head and the TB.
I'm not saying you didn't have issues with it as anything is quite possible and I don't take this the wrong way in the least, in fact I'm glad to hear of others experences beyond my own. All I know is I never had any problems with the stuff.
Good heads up tho Dreamer!
Old 10-24-2006, 11:23 AM
IMADreamer's Avatar
It's possible I just had a fluke occurance too. I thought everything was holding up well and the day I noticed it I actually was going to remove the coil cover to paint it. I then saw the bubbles which were very small, about the size of a ball point pen ball and I decided to try and find a high heat solution. All of the bubbles were in an area with in an inch of the engine itself, the rest of the cover was still in great shape.
Quick Reply: Color matched SPRAY PAINT from GM!
