Official Retrofit Thread
Old 10-21-2010, 08:34 AM
  #126
Gestapo007's Avatar
I think im gonna retrofit a set of FX-r's into my Gen 3's. Seems pretty straight forward. Wouldnt need a shroud since the trim inside the light is one. just unmount the gen 3, mount up new one. wire it up and go
Old 11-02-2010, 05:30 AM
  #127
Acey's Avatar
I'm thinking about doing this too. Can anyone confirm that FX-R's will fit into gen 3?
Old 11-17-2010, 04:39 PM
  #128
damien's Avatar
Who makes a good retro fit?
Old 11-17-2010, 04:42 PM
  #129
AWD > FWD
TommyP's Avatar
No one's done it yet, but you could be the first . The most of retroing is doing custom work, I'm sure some will be needed, but they should easily fit overall.
You could! streetracinazian is a vendor on here who makes custom retros. Gonna be expensive though.
Old 11-17-2010, 05:22 PM
  #130
damien's Avatar
I absolutely can not. I suck at taking the headlights apart and putting them back. Much rather pay for it to be done.
Old 11-17-2010, 07:26 PM
  #131
b00sted06ss's Avatar
[QUOTE=stealthy1ss;4997711][QUOTE]
a little to much shroud for me lol
Old 12-26-2010, 02:37 PM
  #132
D-mac's Avatar
Some great looking headlights in here
Old 02-13-2011, 02:13 AM
  #133
JL-KA's Avatar
RX330s in Gen4s
Morimoto 3Five Ballasts
Osram CBI Bulbs(OEM, 5000k, 3400 lumens)
Output shots are underexposed
Old 02-13-2011, 08:04 AM
  #134
NCC-2000's Avatar
My retro is still a work in progress but here's a mock up of the end result:
Old 02-13-2011, 12:06 PM
  #135
JL-KA's Avatar
You tryin to outdo me? Lol. What projectors are you using?
Old 02-13-2011, 12:23 PM
  #136
Gestapo007's Avatar
everyone retrofitting gen 4's now? damn i gotta get my gen 3's done bu tthere a nightmare! And how come after u retrofit a gen 4 the right light is STILL brighter than the left one
Old 02-13-2011, 12:32 PM
  #137
NCC-2000's Avatar
I moved the projector the gen4s come with to the high beam location, and removed the cutoff shield in the process. I replaced the low beam with Morimoto Minis and plan to wire up my harness so that all four lights are on for highs while the Morimoto handles the lows.
Old 02-13-2011, 12:54 PM
  #138
Acey's Avatar
Cool, I'm doing almost the exact same thing with my gen 3's starting in a few minutes!
Old 02-13-2011, 03:03 PM
  #139
Acey's Avatar
3rd gen left, Morimoto Mini right:
They're very very very close in size. But the holes are different so actually mounting it so it can be aimed is another matter.
Old 02-13-2011, 03:10 PM
  #140
NCC-2000's Avatar
Mounting my Morimotos while retaining the aiming ability was easier than I thought. I just made some small brackets to attach to the "stock" mounting posts. Worked really well.
Old 02-13-2011, 03:33 PM
  #141
Acey's Avatar
The Morimoto's appear to fit right onto the stock 3rd gen posts. God have mercy! Haven't actually got it to screw in yet but it's looking like a straight swap.
Old 02-13-2011, 05:29 PM
  #142
JL-KA's Avatar
Some projectors are just brighter than others. As a rule of thumb yuou should put the brighter one on the driver's side. I didn't realize it was brighter though and it was too late. That bulb was also broken in more. I switched the bulbs and they're more even now. It's kinda deceiving though because the upper step overlaps with the right beam making it seem brighter. If I covered one up you would see that they're pretty close.
Old 02-14-2011, 01:19 PM
  #143
Acey's Avatar
The problem you will run into putting Mini's onto the 3rd gen posts:
It sits well below the actual opening. FML.
Old 02-14-2011, 01:35 PM
  #144
elecblue06's Avatar
those look fandamntastic, iwant to see those running
Old 02-14-2011, 02:11 PM
  #145
JL-KA's Avatar
I had that problem with 4th gen's too and had to move the shroud/high beam. What I would do is make a mounting plate for the mini that puts it in the correct position and mounts it in the stock location. Then I'd modify the back of the housing as necessary. Not sure exactly what you're working with but most likely you have to open the hole(rear) more since the projector is being moved up. I'd then put 3"pvc around it and epoxy(the pvc) to the housing and fill in the gap that is left below with plexiglass or something. Then use a pcv cap to seal it up. Voila!
Old 02-14-2011, 10:55 PM
  #146
heathkidder's Avatar
does any1 know how to change the angel eyes in the retro kits? if so post the how to plz also is there a way to find out the size of the angel eyes or should i just measure and hope its right thanks
Old 02-19-2011, 10:23 PM
  #147
C_A_D88's Avatar
Old 02-24-2011, 11:30 AM
  #148
bspeed's Avatar
my homemade retros
did them myself and vic red color matched paint aswell. first time i ever took my headlights apart and retro fitted anything, i took the super cheap route.
Old 02-24-2011, 01:01 PM
  #149
elecblue06's Avatar
you didnt do shrouds?
Old 02-24-2011, 01:41 PM
  #150
bspeed's Avatar
nope didnt like the shrouds
Quick Reply: Official Retrofit Thread
