Official Retrofit Thread
Old 02-24-2011, 01:52 PM
  #151
JL-KA's Avatar
Huh...
Old 02-28-2011, 11:08 AM
  #152
flyy's Avatar
I got terminators coming from streetracinazian.
Can't wait!
Old 03-17-2011, 11:29 PM
  #153
2009CobaltLT's Avatar
Coming soon...
Old 03-28-2011, 11:12 AM
  #154
bspeed's Avatar
turned out better than i thought, ebay kit g3 8k hids waiting on ballast. atm
Old 03-28-2011, 12:09 PM
  #155
Love the color match
Old 03-28-2011, 05:16 PM
  #156
bspeed's Avatar
thanks, pep boys sells the gm vic red for cheap. and some other colors
Old 03-30-2011, 12:32 AM
  #157
onyx8's Avatar
Maaan...I was wondering how color-matched retros look. I was considering some myself. I just don't know if I like them or not.......
Old 03-30-2011, 01:34 AM
  #158
BlueBalt1113's Avatar
07metallicss will like these....made by streetracin
color matched retros with blue demon eye 8k hids and gatlin shrouds i think lol
with demon eye on
Old 04-21-2011, 09:28 PM
  #159
vahdyx's Avatar
Can I see every ones gapping. I wanna see if mine is normal.
Old 04-22-2011, 12:52 PM
  #160
JL-KA's Avatar
Gapping?
Old 04-22-2011, 02:22 PM
  #161
ssweeet's Avatar
Bumper and hood gap, I'm assuming.
Old 04-22-2011, 10:01 PM
  #162
vahdyx's Avatar
correct,
I have quite the gap, it's like the headlight is too small. Maybe I just didn't notice with my stock lights.
Old 04-22-2011, 10:20 PM
  #163
AWD > FWD
TommyP's Avatar
your headlights might not be seated correctly, those tabs are pretty difficult to get to sit in the slots correctly. You should have the same amount of gap that you did stock.
Old 04-23-2011, 09:51 AM
  #164
vahdyx's Avatar
I'll take a photo to show you guys. Maybe you can walk me through fitting it better.
Old 04-26-2011, 11:53 AM
  #165
The Azian's Avatar
Anyone know the temp needed to bake the headlights to get them apart??
Old 04-26-2011, 12:18 PM
  #166
AWD > FWD
TommyP's Avatar
215 works perfectly
Old 04-26-2011, 01:05 PM
  #167
The Azian's Avatar
Originally Posted by TommypSS/TC
215 works perfectly
Thanks man. About how long do you leave them in? Also do you no if u add neww sealer when re-assembling the headlight?
Old 04-26-2011, 01:11 PM
  #168
AWD > FWD
TommyP's Avatar
I leave them in for about 7 min the first time, then reheat for 3-5 min as needed. Don't worry, you're not gonna melt them at that temp, just don't leave them in for an hour or anthhing like that. while I had the oven on I took a small screwdriver and cleaned out most of the glue from the channels and a putty knife to clean it off the lenses. Then when you seal the lights, put new sealant in the channels, press the lens into the slot, and put them back in the oven to soften the adhesive, then clamp the lens and housing together, that should give you a nice seal
Old 04-26-2011, 02:32 PM
  #169
heathkidder's Avatar
i never use new sealant i just use old stuff on there and never had any issues with fogging
Old 04-26-2011, 03:27 PM
  #170
The Azian's Avatar
Thanks for fillin me in man I'm gona try and reuse the stock sealent. And there's. No special trick to unclipping the housings apart is there?
Old 04-26-2011, 03:35 PM
  #171
AWD > FWD
TommyP's Avatar
Make sure you remove the three screws in the back of the light. Be VERY careful bending the clips up, they break extremely easy. I broke one on both of my lights. Doesn't matter all that much as long as you use a good sealant. Also be careful because the lip on the top of the housing is very flexible and easy to break.
Old 04-26-2011, 05:34 PM
  #172
The Azian's Avatar
Roger that !!
Old 05-19-2011, 10:52 PM
  #173
matt638's Avatar
ok im about to order some retro's.. and im a huge headlight noob what are SLIM Ballasts? do i need them?
Old 05-19-2011, 10:55 PM
  #174
LS6Rally's Avatar
Theyre about half the size of standard ballasts and no you dont need them
Old 05-19-2011, 10:57 PM
  #175
matt638's Avatar
thanks for the help man!
Quick Reply: Official Retrofit Thread
