Official Retrofit Thread
Old 05-19-2011, 11:01 PM
  #176
AWD > FWD
TommyP's Avatar
Guess I should post up my new ones
Morimoto Mini H1 projectors with top washers removed (slight color mod)
Morimoto 35w 5000k bulbs with Morimoto 35w ballasts
TRS 9007 relay harness
E46 extended shrouds with 100mm halo
Black Painted Housings
5 Lanes wide!
Old 05-19-2011, 11:30 PM
  #177
Mine are fogging on passenger side. resealed and everything. any ideas?
Old 05-20-2011, 12:27 PM
  #178
JL-KA's Avatar
TL Projectors
E46 Extended Shrouds
Morimoto 3Five Ballasts
Osram CBI Bulbs(5000k 3400 lumen)
Old 05-21-2011, 11:23 AM
  #179
AWD > FWD
TommyP's Avatar
I just drilled holes in mine, I couldn't get them to stop leaking nonmatter what. I think my problem was I had too good of a seal.
Old 05-21-2011, 11:34 AM
  #180
mkulrey13's Avatar
Check the backside where the bulb mounts.
Old 05-21-2011, 11:40 AM
  #181
N1ckateen's Avatar
5 Lanes wide!
Man i'm gonna have to like schedule a day to come out and have you mess with mine because i'm no where near this output!
Old 05-21-2011, 12:41 PM
  #182
what specifically am i checking there? looks seated good
Old 05-21-2011, 12:49 PM
  #183
mkulrey13's Avatar
Mine is exactly the same. Are you sure the bulb is seated correctly? You also said you believe yours is 8k. 8k and 5k is night and day difference in terms of brightness. As per our PM we will warranty the bulbs and get your 5k if you think you have 8k.
Old 05-21-2011, 12:54 PM
  #184
thedude411's Avatar
oo a dock is a great place for output photos. that would have never occured to me
Old 05-21-2011, 12:59 PM
  #185
N1ckateen's Avatar
I would, but I can't afford any of the shipping atm. not til payday at least.
Old 05-21-2011, 01:41 PM
  #186
mkulrey13's Avatar
Warranty is free unless you want to send us the old bulbs back.
Old 05-21-2011, 01:45 PM
  #187
driving during day
Old 05-23-2011, 01:02 PM
  #188
N1ckateen's Avatar
i put a 5k bulb in my passenger light and a 6k bulb in my drivers side light last night and they are completely identical. also how you said 112 is 5k and 6k. the 6k bulb said 102 on it?
Old 05-23-2011, 04:42 PM
  #189
mkulrey13's Avatar
Numbers on back change just like GM paint codes lol. They change over time. Again ive already told you we can warranty them if you would like.
Old 06-02-2011, 12:21 AM
  #190
Hammbones's Avatar
Has anyone tried a High Beam Transplant from any Generation Projector Headlight? If I have to frankenstein the lenses from my Gen 1's I might as well use the High beams?
Old 06-04-2011, 01:02 AM
  #191
SuperRedSS's Avatar
Has anybody thought of or tried putting clear lenses in our foglight projectors? I noticed clear lenses at retrofit source and wondered how much better light output would be compared to stock
Old 06-04-2011, 08:51 AM
  #192
C_A_D88's Avatar
.... And What r they now?
Old 06-04-2011, 08:57 AM
  #193
mkulrey13's Avatar
Ive always wanted to do the blazer fogs in ours but no time for that work.
Old 06-04-2011, 09:06 AM
  #194
elecblue06's Avatar
i should do this my stock lenses are all fucked up
Old 06-04-2011, 09:42 AM
  #195
My friend took a set of projectors off of one of the Gen Headlights and said they went in like stock on the fogs and says light output is 100 times better
Old 06-12-2011, 01:48 AM
  #196
Hammbones's Avatar
1) Valeo / Audi A4 (9006 Type)
2) E-46 Extended
3) DDM 55W + Wiring Harness (5000k)
Old 06-13-2011, 08:51 AM
  #197
dayhoff35's Avatar
to those with the fx-r projectors some people say you have to cut to mount them. Do you? What part do you have to cut.
Old 06-13-2011, 01:07 PM
  #198
JL-KA's Avatar
You have to cut a hole in the reflector to slide the projector back
Old 06-13-2011, 01:15 PM
  #199
dayhoff35's Avatar
how much better is the output compared to the morimoto minis though, is it worth the extra work?
Old 06-13-2011, 04:17 PM
  #200
JL-KA's Avatar
Definitely worth it.
Quick Reply: Official Retrofit Thread
