Autocross and Road Racing Road racing is not “street racing”
17x9s have arrived
Old 02-06-2014, 04:11 PM
  #276
Grave's Avatar
Originally Posted by m33pm33p
Good to know, 275/35 on stock rim tho! oh dear. How did the rs3's treat you?
I wasn't involved with 275s on the stock wheels That was someone else.
The rs3s were great. I'm planning on staying with them, if they're available. They seem to be in short supply right now.
Old 02-14-2014, 02:24 AM
  #277
GR1VLET's Avatar
I have been noticing the same thing. I noticed you said that you may go to a narrower rear tire... I'm guessing to help with rotation - what is your setup now? Rear sway bar? I'm hoping that square stance 255s with the xxx bar should be pretty close to neutral (with yyzs and konis).
Old 02-14-2014, 08:27 AM
  #278
Grave's Avatar
As far as the R-S3 goes, I've been seeing rumors on the interwebs that the R-S4 will be coming out within a few months.
For me, 255s and a XXX bar was too much. I ran with no bar the last few events and it felt great, aside from the rear tires skipping a bit when sliding. That starts getting a bit unpredictable. Dropping down to a 245 will alleviate that hopefully. This year I'm going to start out with no rear bar, same tires as last year, and bc coilovers for the looks.
Old 02-14-2014, 04:25 PM
  #279
GR1VLET's Avatar
I 'know a guy' who might want them yyz's!you didnt consider the V2s for a bit more low?
Old 02-14-2014, 06:27 PM
  #280
Grave's Avatar
No. I'm pretty sure more negative camber is needed for the tires to clear the fender for anything much lower than V1s.
Old 02-14-2014, 08:17 PM
  #281
GR1VLET's Avatar
Hmm, jboogie was on peddars, no? I thought John said the v2/3s sat at the same height as new pedders but with higher spring rate. I'll be slotting the struts for more camber anyway, so it shouldnt be a problem.
RaginChopsuey
10-27-2015 01:27 PM
jmelton327
Wheels and Tires
10-02-2015 01:54 PM
royce777
09-28-2015 07:11 AM
cobaltchris
02-28-2005 05:12 PM
Quick Reply: 17x9s have arrived
