Autocross and Road Racing Road racing is not “street racing”
Official: Autocross and Road Racing Thread
Old 09-14-2014, 03:36 AM
  #101
Foximus's Avatar
picked up some nice Sparco Evo2 seats today. 32lbs for both. that will help. and way more comfy than my old metal tube and spring corbeau in there now. Now I just gotta figure out the best way to mount them.
Old 09-14-2014, 03:51 AM
  #102
Omiotek's Avatar
Wedge engineering makes brackets
Old 09-14-2014, 04:40 AM
  #103
Foximus's Avatar
I saw those. Would I need those brackets + the sparco side mounts? The wedge website is a bit vague, and has no actual photos of the mounts.
Old 09-14-2014, 08:08 AM
  #104
Omiotek's Avatar
The wedge brackets are like the brand planted where it's the base bracket that you bolt your side brackets onto. The base bracket just gives a surface to mount from car floor to side seat bracket
Old 09-14-2014, 09:11 AM
  #105
yellowsupercharged06's Avatar
Powell makes some brackets for sparco seats. I like mine definitely thicker than the other options out there. I compared them to the corbeau ones fyi.
Old 09-14-2014, 08:54 PM
  #106
Grave's Avatar
By the narrowest of margins, I managed FTD against this turbo Miata today. He got me yesterday.
A video of my fastest run.
Old 09-15-2014, 09:45 AM
  #107
ligit run , what tires are you running ?
Old 09-15-2014, 04:21 PM
  #108
Foximus's Avatar
Im wondering if the sparco side mounts will bolt to the corbeau sliders I have in the car currently. hmmm
Old 09-15-2014, 04:52 PM
  #109
they have diagrams of the seat bolt patterns online
Old 09-15-2014, 08:45 PM
  #110
ssyellow's Avatar
Along with that, who tuned your car? She scoots quite well.
Old 09-16-2014, 01:32 AM
  #111
Grave's Avatar
245/40/17 Hankook Z214 C71 aka r-comps/slicks
I'm currently running an E85 tune by MikeM. First gear still needs to be turned down a bit as you can see in the video.
Luckily I'm in second gear after the start on 90% of the courses. There is enough torque to pull out of most corners and enough gear to not shift into third. I've logged up to 70mph in second gear at about 6500rpm. I should probably do valve springs at some point to raise it a bit more.
Old 09-16-2014, 09:35 AM
  #112
yeah they looked like slicks wasnt sure what ones tho, i wish i could run slicks (lsj knuckles )
i cant wait to get back to the next autox with my e85 m62 setup ... should be pretty good.
Old 09-16-2014, 03:58 PM
  #113
Foximus's Avatar
Originally Posted by 1Panel2NV
245/40/17 Hankook Z214 C71 aka r-comps/slicks.
I miss those. stepped back to RS3's this year to shake the car out for time attack over autox, but i liked the 'kook slicks over hoosiers.
Old 09-16-2014, 08:03 PM
  #114
Omiotek's Avatar
we got you covered there.... made locally too.
Old 09-16-2014, 08:18 PM
  #115
Omiotek's Avatar
for time attack an a compound is where its at. usually you will run your fastest laps within the first 8 and that's when I find the r compounds to just start heating up
Old 09-16-2014, 10:50 PM
  #116
andrewcarr1993's Avatar
I think you'll be fine on the LSJ knuckles, just ask Foximus I'm sure he's still on the stock ones and has driven his car harder than most ever have.
Old 09-16-2014, 11:22 PM
  #117
Whitnith's Avatar
I run slicks with no problems on my LSJ.
Old 09-17-2014, 09:47 AM
  #118
you guys aint scurd of breaking the knuckles ??? or is that just non sense that came about over the years.
Old 09-17-2014, 10:36 AM
  #119
Powell Race Parts's Avatar
In development, the lsj stock knuckles broke at a place called the >toilet bowl> at the GM Proving grounds test track. Only one instance. But the race cars were all built with the G6 knuckle and upgraded grand am wheel bearings and special axles . The stock LSJ knuckle will fracture between the strut bolt mounting bolts if crashed on a curb or somesuch.. The upgraded G6 or LNF ones will bend not break nor will the arms, (they will bend instead) and the cradle will yield as well when crashed. Thats my experience.
Old 09-17-2014, 10:40 AM
  #120
so basically if i stay off of the toilet and not crash i will be fine.
Old 09-17-2014, 10:51 AM
  #121
colodude18's Avatar
Sub'd
Old 09-18-2014, 03:53 PM
  #122
Foximus's Avatar
Only suspension failure I ever have had was a shock. But Ive done well with not hitting things with the front of the car >__>
So I have a guy at work talking to me about building a custom carbon sunroof plug to get rid of the glass+ track. Looking like for the carbon work and the mounting pieces right around $500. Its very tempting. It would be nice to pull weight out of hte car that high up.
Old 09-18-2014, 03:57 PM
  #123
got some yyz springs in the mail today ... time for the pedders to hit the road.
that sunroof thing is an interesting idea. but how much weight would that actually save ?
Old 09-18-2014, 04:11 PM
  #124
speedbugy996's Avatar
I've logged something in the area of 8000 track miles on my RL, about half of those on slicks, no fails on steering knuckles. I'm not overly shy of climbing the curbs on track either.
Old 09-18-2014, 04:44 PM
  #125
Foximus's Avatar
Thats what I am trying to figure out. Its still being mulled over. Also discussed maybe just changing the glass for carbon, heh. Car comes back from the shop tonight, gotta do an oil change and brakes this weekend, may pop the head liner and try and pull it just to see what it weighs.
My very rough guess is 20 pounds? Between the glass and the steel track, and the motor. Becomes a "is it worth $500 to pull that from the top?" Im trying to figure out ways to get more weight out from the car to help against the legion of Honda's I'm up against at time attack, heh.
Quick Reply: Official: Autocross and Road Racing Thread
