Autocross and Road Racing Road racing is not “street racing”
Official: Autocross and Road Racing Thread
Old 06-16-2014, 10:51 AM
Dyn0mitemat's Avatar
Heel-toe aint too bad in this car. I just wish there was more room down by the gas pedal. I wear size 12 boots (or big shoes) usually and I got no room to 'twist' my foot like the traditional method suggests. I normally just use the ball of my big toe on the brake pedal and twist my ankle down to the gas so the right side of my foot hits the gas. Don't have any problems.
I just wish there was more room, my buddies evo, 350z, hell even my jeep, have plenty of room to twist even a big foot to the side and get some proper footwork in. Nothing I can't overcome, I've been doing it this way in my lsj and now lnf for a few years, and I feel confident about it, but it'd still be nice...
Old 06-16-2014, 10:58 AM
yellowsupercharged06's Avatar
my knees are in the steering column lol so heel-toe is hard for me too ... also got big feet probs.
6' 5 problems
Old 06-16-2014, 11:10 AM
Yea I'm 6'3", I'm skinny (only 165#) but long legs dont help
Old 06-16-2014, 11:40 AM
ssyellow's Avatar
6'4" and I have no problem. I'm good at getting into tight places though hah.
Old 06-16-2014, 12:07 PM
yea lanky over here too lol 170 lbs
Old 06-16-2014, 12:20 PM
charlster's Avatar
Originally Posted by NickD
I haven't had any issues myself. Just never, use your e-brake after a session, turn the car off and leave it in gear. Have you also tried adjusting the e-brake?
Yeah, I don't put my ebrake up after i'm done with a run. No, I haven't adjust the brakes yet although that's what I plan to do.
Old 06-16-2014, 12:25 PM
charlster's Avatar
Here's a shot of my car from the last autocross. Car is all stock. Currently on Dunlops Z2's.
Old 06-16-2014, 01:30 PM
ssyellow's Avatar
Nice, I'm on Z2's also. After a two week break due to finals I'll be at another auto-x this Sunday.
Old 06-16-2014, 06:01 PM
m33pm33p's Avatar
Driver training course on saturday and then auto x sunday. Gonna be a fun weekend on the new wheels.
Old 06-17-2014, 06:22 AM
Foximus's Avatar
Car is back from the shjop with the engine fixed, oil leak gone, and steering rack not walking around. Hoping to get to a track day as soon as I stop having "mandatory saturdays" at work. Just need to get another air tank.
Old 06-23-2014, 03:18 PM
  #36
GR1VLET's Avatar
Charlester - you can run one swaybar in street classes - get a rear swaybar to help with that roll!
Old 06-23-2014, 03:34 PM
  #37
GR1VLET's Avatar
Mongorat - what is that splitter made from? ABS?
Old 06-24-2014, 01:08 AM
  #38
m33pm33p's Avatar
Obviously having a good time on the new wheels, had my rear shocks set up a little hard and car was fairly loose in the corners and braking. Left a lot of time on the course. Slowly getting the car dialed in.
Old 06-25-2014, 04:54 PM
  #39
what does everyone have there koni Rears set at ? need to adjust mine.
Old 06-25-2014, 05:50 PM
  #40
andrewcarr1993's Avatar
Half turn from full soft, or is it a full turn, I forget now.
But check out this
https://www.cobaltss.net/forums/susp...adjust-277606/
Old 06-25-2014, 07:03 PM
  #41
ssyellow's Avatar
Mmm, meaty. Did you say you were on 255's?
Old 06-25-2014, 07:39 PM
  #42
mongorat427's Avatar
Yes 1/8 ABS Its durable and mounted with breakaway bolts
Old 06-25-2014, 09:05 PM
  #43
speedbugy996's Avatar
I run track days and high speed autox, which is just a Top Gear lap, standing start from pit lane, once around the track. As for my car....
06 Ion Redline with comp package.
Upgrades to power/cooling:
M62 ceramic coated rotors on a 2.9
GMR head, reworked with supertechs by Powell (big 32hp gain on the head alone, ft/lbs up by 22)
K&N cai (soon to come off and go back to stock)
Pwerks tune
zzp stage 3 injectors
zzp long tube header w/cat
Powel pcv system
Powel trapdoor oil pan
ced wheel hop kit (axles and mounts)
Griffin intercooler, dual pass, soon going to single pass from Powel, opt b and I flipped the air dam for more of a forward bite in the air and Pwerks fabbed up a frame to support it at track speeds.
I'm forgetting something....anyway 260hp 238 ft/lbs
brakes: Brembo kit up front, stock rears, pads vary depending on prices at time. Usually stock brembo pads and stoptech track pads on back.
Suspension: all things powel here lol...
Fe5 control arms with Powel bushings, yyz ver1 springs, koni yellows at 75% stiff front, 25% rear. eibach front bar(not worth doing btw), xxx rear bar from powel, twisting beam bushing...again from some dude in Canada, Moog endlinks.
Trans: lsd, 4.45, hurst short throw
Tires/Wheels: street, Z2s 235/40/17 on sparco asseto gara in black. track OZ allergita or however ya spell it with hoosier A6s 225/40/17.
I'm probably forgetting something, but ya get the idea. Going to single pass and tvs with a powell fuel set up to support it all.
ah...alignment specs: -2.0 camber up front, -.5 ish or best I can get on rear caster 3.5, and toe dead 0. I would go with a bit of toe out if I wasn't daily driving the car and probably add more neg camber too.
Old 06-25-2014, 09:33 PM
  #44
Half turn from full soft, or is it a full turn, I forget now. But check out this https://www.cobaltss.net/forums/susp...adjust-277606/
Yeah i saw that thread i think mine are set at 1/2 turn ... Think there jacking down the pedders. Guna try 1/4 turn and see how it works out.
Time for some yyz
Old 06-25-2014, 10:03 PM
  #45
Powell Race Parts's Avatar
Time for some yyz
yup.
i may adjust my konis harder at the rear....
and was thinking of retuning rear springs. looking at the data. thinking. lol
pedders lose so much rate its a crime.
and stock sc springs? found some rears broken at the bottom coil today. wondering if i should be surprised
Old 06-27-2014, 12:26 AM
  #46
Grave's Avatar
Now I just have to wait for the next autocross...
Old 06-27-2014, 09:20 PM
  #47
m33pm33p's Avatar
Droooooooooool
ventus z214's?
And yes I am 255/40/17 RS3's
Old 06-27-2014, 10:16 PM
  #48
63 Nova SS's Avatar
i need to forget about drag racing and get into this instead as these cars are much better handlers than drag cars. Already got some pretty good suspension stuff on.
Old 06-27-2014, 11:36 PM
  #49
Haven07's Avatar
I'm hoping my tvs set-up will fair well in autocross. Anyone run a tvs set -up for auto cross?
Old 06-28-2014, 07:40 AM
  #50
Grave's Avatar
Droooooooooool
ventus z214's?
Yep. I had to go with 245/40 because they don't have a 255. They fit the wheel better than I was expecting. I think I'll try a 255 of a different brand next time though.
Quick Reply: Official: Autocross and Road Racing Thread
