Official: Autocross and Road Racing Thread
#111
245/40/17 Hankook Z214 C71 aka r-comps/slicks
I'm currently running an E85 tune by MikeM. First gear still needs to be turned down a bit as you can see in the video.
Luckily I'm in second gear after the start on 90% of the courses. There is enough torque to pull out of most corners and enough gear to not shift into third. I've logged up to 70mph in second gear at about 6500rpm. I should probably do valve springs at some point to raise it a bit more.
#114
we got you covered there.... made locally too.
#115
for time attack an a compound is where its at. usually you will run your fastest laps within the first 8 and that's when I find the r compounds to just start heating up
#119
In development, the lsj stock knuckles broke at a place called the >toilet bowl> at the GM Proving grounds test track. Only one instance. But the race cars were all built with the G6 knuckle and upgraded grand am wheel bearings and special axles . The stock LSJ knuckle will fracture between the strut bolt mounting bolts if crashed on a curb or somesuch.. The upgraded G6 or LNF ones will bend not break nor will the arms, (they will bend instead) and the cradle will yield as well when crashed. Thats my experience.
#122
Only suspension failure I ever have had was a shock. But Ive done well with not hitting things with the front of the car >__>
So I have a guy at work talking to me about building a custom carbon sunroof plug to get rid of the glass+ track. Looking like for the carbon work and the mounting pieces right around $500. Its very tempting. It would be nice to pull weight out of hte car that high up.
#124
I've logged something in the area of 8000 track miles on my RL, about half of those on slicks, no fails on steering knuckles. I'm not overly shy of climbing the curbs on track either.
#125
My very rough guess is 20 pounds? Between the glass and the steel track, and the motor. Becomes a "is it worth $500 to pull that from the top?" Im trying to figure out ways to get more weight out from the car to help against the legion of Honda's I'm up against at time attack, heh.
