Manitoba SS 2014
#2478
Its the end of the season warm those r888s up!!
#2483
Sounds like we are gonna get some runs in on Sst night! Won't be anything like Taylor's but I how I can get some battles in
#2492
Good work Tom also remember glazing putty is your friend for small pin holes and such I usually prime sand putty repeat
#2493
Ya I got some glazing puddy, I guess that will be after some bondo and sanding. I gotta fix a few larger holes in the fiber glass where there is a void underneath caused by the bad way I fiberglassed at the beginning. Once those are fixed up ill do some bondo.
#2495
A little comparison on a bored day at work. Here is a Virtual Dyno graph of Dustin's car and my car overlaid. Take these with a grain of salt, but I do know that with how it is setup right now it has gotten me within 2% accuracy and tighter on 3 setups/cars that I have logs of right before they went on an actual dynojet. My graph starts later because I didn't go WOT until 4850 rpms or so and full boost hits around 5200 in this run. My weight is so high because I had 3 people in the car, one at 230lbs, one at 180lbs, and myself. Then the usual stuff like a pretty full fuel tank and typical **** in the car. Anyone familiar with virtual dyno knows what I'm talking about.
Dustin's car - Red line:
Stock Gen 3 2.0 - 9.2:1 CR, ported head, ZZP S2 turbo cams
S252et turbo setup
94 octane pump gas - no meth
23 psi, 16* total timing, 11.8-11.9 AFR
Still revising the tune, but it's close. Car is begging for a bigger turbo/meth with how its flowing.
My car - Green line:
Gen 3 2.1 9.7:1, ported head, ZZP S2 turbo cams
s259et turbo setup
E85 fuel
30 psi, 20* total timing, 11.3 AFR
Usually run to 8k, power usually peaks at 7600-7700
S252et turbo setup
s259et turbo setup
E85 fuel
