Manitoba SS 2016
#478
When it rains it pours...
Rear brakes wouldn't stop making noise. Battery warning light came on, drove to my girlfriend's place, slowly died while parked so I shut it off. Battery is flat.
#482
Got it all fixed up. Took 2 trips to Parts Source, to return the rented tool that didn't work.
Bought a tensioner release tool and clip tool at PA. Wrench didn't fit with the adapter. Could just get the adapter in on it's own. Went back to PA and bought two wrenches. One that fit the adapter and used the 2 wrench technique. Had the belt on in 20 seconds.
Went back and returned everything no questions asked.
#483
Starting to think I got some air into my abs unit when bleeding my caliper the other day. Fluid level dropped way quicker than I thought it would.
Now to find a tech 2 for an abs bleed procedure.
Car just doesn't have the braking force it used to.
#488
The rear bracket bolts are a bitch they are a 10 mm bolt that is inside the sub frame with a 15 mm nut on top of the sub frame but under a double layer of sheet metal that doesn't have room to put a socket of a box end wrench on need to use an open end wrench. the 10 mm side stripped on me so I slammed on a smaller socket and I ended up shaving a 15mm box end wrench on an angle and trying to bend as much of the metal flange as possible. also there are brake lines on the driver side that limit your access even more. Its designed that you should drop the sub frame. Fookin stupid.
