Manitoba SS 2016
#253
So is the Powell PCV system install really as easy as "Removing the dipstick and replacing it, and removing the pcv hose from the turbo are the toughest parts of the job."
I typically like to have some better visual instructions even though I can kind of picture what to do just from looking at it. How hard is it to get to the pcv hose on the turbo?
#254
honestly is super easy if you destroy the hose when taking it off, just pry it off with a pair of needle nose pliers. if you don't want to ruin that hose then your best bet is using 4 metal zipties and lots of patience
#255
I believe u have to pull the fitting out and tap the VC
#257
not doesn't come with tap,use 1/8 npt tape. to get the current thingy out of the cover, just put needle nose plyer on either side, or grab it with a vice grip and then hit the vice grip with a hammer as close to the thingy as u can. tap it, don't have to hit hard. if it doesn't come, apply heat. mine came out super easy. when u tap the hole, put grease on the tap and the filings will stick to the tap instead of falling inside the valve cover. it really is very easy. if u have a zfr, I hope u told powell cause u need a 45 degree fitting for the turbo instead of the one he gives for stock turbo or ur line wont fit on
#259
Tom you gonna dyno as well?
#263
#273
Well ordered some new rotors and pads yesterday off amazon. Cross drilled and slotted with black anti rust coating on them should arrive in a few days. Give em a shot. My fronts are pretty warped now so I need to do some thing. Should also look sweet just need to get some yellow caliper paint and do those at the same time.
#275
