Displeased with Performance Autowerks
just recently found out from the machine shop the "upgraded high performance" head gasket Dave sells for $150 is nothing more than the $50 OEM gasket with a spray on sealer. Dave also confirmed this after I asked about it. I can understand an upcharge of a sort for time & materials but 3 times the amount doesn't seem right in my opinion. Just FYI...
Just for reference, the Upgraded high performance head gasket you're talking about is this one? WERKS Racing 2.0L LNF Street/Race MLS Head Gasket Kit
They do not appear to be the same, you sure he was meaning that they were the same or would function the same? Perhaps you should speak with him again to get some clarity.
Dave himself told me it is an "upgraded" oem gasket with a coating for better sealing.... spray on "hi-tack" sealer has been used on multi layer steel gaskets forever... its nothing that special makes the gasket worth 3 times the amount of an oem which would hold up just as good as the "upgraded"
sptrdss
10-22-2015 12:00 PM
