Drag Racing Kindle Racing and Dalcorp Racing
OFFICIAL: Difference between SLICKS and Drag Radials
Old 02-17-2009, 02:25 PM
ralliartist's Avatar
put it in 2nd, pull the ebrake. Dump the throttle in the water box and throttle it till smoke comes out. It's easy.
Old 02-17-2009, 07:10 PM
Deathscythe's Avatar
sounds easy enough.
Old 02-17-2009, 07:13 PM
EXsoccer1921's Avatar
i thought this was kinda common sense??? lol....i guess it is just to me since i've spent a lot of time researching tires
Old 02-18-2009, 01:37 AM
no, unfortunately, there are a lot of confused people out there. I aim to make them less confused. LOL.
Old 02-18-2009, 06:22 AM
well, thats a nice goal haha
Old 02-18-2009, 01:38 PM
Originally Posted by Milkey1
ralliartist. he has an evo. he lies to everyone. he had a stock evo then put the cobalt wheels and body onto it and ran a 13.2 stock with a stock evo. just looks like a cobalt. you see his launch video's? ***** sick! he haz you all fooled! dupercharged!!! he now switched the evo to a corvette engine!!
Old 02-18-2009, 04:47 PM
car_guy_09's Avatar
x2....
Old 02-19-2009, 01:52 AM
Mikey1=CBodnar
fyi
Old 02-19-2009, 07:46 AM
Edubs's Avatar
Originally Posted by ralliartist
Mikey1=CBodnar
fyi
That explains a lot...
Old 02-19-2009, 07:00 PM
car_guy_09's Avatar
Mikey1=CBodnar
fyi
Yes... Yes it does
Old 02-19-2009, 07:37 PM
  #36
leviticus88's Avatar
Bro, you completely misunderstood me. Just looking for rims...
Anywho, I did a little searching last night and found the best place was, in fact, Tire Rack's winter selection. Actually came across quite a few choices and think I've come to a decision.
Sport Edition F10's. 16X7 @ 17.5lbs:
Pretty similar to my OZ's if painted black except for the whole 6 spoke/ 5 spoke thing...
Any link to the sports for sale? I couldnt find them, thanks!
Old 02-20-2009, 07:28 AM
  #37
Edubs's Avatar
http://www.tirerack.com/wheels/Wheel...Silver+Painted
Old 02-20-2009, 05:32 PM
  #38
Thanks for the link but when you enter in a 2006 Cobalt SS/SC it won't give you the option to buy these and no prices is ever given. Maybe I'm just doing it wrong? Thanks again!
Old 02-20-2009, 07:53 PM
  #39
you need to enter hhr lt.
Old 02-20-2009, 08:13 PM
  #40
Thanks! I appreciate it!
Old 02-20-2009, 08:17 PM
  #41
cakeeater's Avatar
good post man. I think it's important to note that there are some DR's out there that are just barely streetable and shouldn't really be used on any kind of daily basis. You addressed it, i just wanted to emphasize it again because i have seen multiple people using them as DD tires. for example, ET drags are a HORRIBLE street tire and are basically slicks despite being called a drag radial.
tires are far more complex than people realize. I always advise people to talk to someone else when they ask me about tires because they are just a science in themselves.
again, good post. good sticky.
Old 02-21-2009, 01:36 AM
  #42
COHBALTSS's Avatar
Something else worthy of mentioning
The soft sidewalls of slicks or bias ply DOTs like ET Streets/Hoosier Quick Time Pros are easier on half-shafts, axles, etc. Yes they have more ultimate traction, but the sidewalls absorb much more shock on the launch. Launching a manual trans car on drag radials is tricky and often a hit or miss traction situation. Automatics (except trans brakes) hit softer and it's not as much of an issue.
In the early 03-04 Cobra days, many stock 12 second cars were breaking their IRS while some guys were running 10's on the stock IRS without breakage. Besides the obvious wheelhop, the other biggest factor was the tires that enabled the diffs and half-shafts to survive. Some of these guys were consistently dumping the clutch at 5,500 rpms on completely stock rear-ends and drivetrains without breaking, amazing. Of course if you do that over and over you WILL find the weak links and they did...
You're very correct about using some of these so called DOT tires as daily drivers. Some of them are acceptable some are not. For example, Nitto DR's do ok in that situation. On my 500+rwhp Cobra, I used Nitto's daily and found them to give sufficient traction on the street and do OK in rain until there was standing water or until they were worn. Nittos are known to last the longest of the drag radials but also trade off ultimate traction. At the track they SUCKED.
A couple times I mounted up my ET Streets (bias ply slicks with 2 grooves to make them barely DOT legal) the night before and drove to work then to the track to race that night. They sway like a **** and are really not safe as you said. Taking turns or driving over 55mph was ass-puckering. Now for a few hours of Friday night boulevard fun, they're ok, but not as daily drivers.
Old 02-21-2009, 01:38 AM
  #43
good posts guys. Good thread.
Old 02-21-2009, 01:40 AM
  #44
how about mickey thompson sportsman s/r's as a street tire???
Old 02-21-2009, 01:44 AM
  #45
kwest's Avatar
rallieartist- you think the best bet for ss/sc is to go with a 16inch rim and get the M T drag radial you posted a link on right? the 225-50-16 will fit with no issues on a lowered balt? And is it ok to run the steel wheels with the tires you chose, like these at tirerack.com.... http://www.tirerack.com/wheels/resul...ar=&sort=Brand
doesnt have a weight on them..
Old 02-21-2009, 10:12 AM
  #46
yea, those are M T drag radial, they are HOOSIER DOT drag radial. But they are just a DOT approved cheater slick. They shouldn't be used on the street. They should be good on a lowered balt and those steelies should work.
Old 02-21-2009, 10:59 AM
  #47
ralli answer i question bitch!!!!!!
Old 02-21-2009, 05:21 PM
  #48
kwest's Avatar
I dont really like SHOULD and SHOULD work...hah Id rather know before spending over $500...
Old 02-21-2009, 09:42 PM
  #49
Edubs's Avatar
Sorry,
Completely forgot to tell you. Go to the winter selection, not wheels. Then enter Cobalt SS/SC. Select 16" options and then skip to wheels. It'll give you steelie selections and just above that will be a link for about 17 alloy choices for us.
Old 02-22-2009, 01:08 AM
  #50
well, I've never used steelies, just the sport edition a7's I bought off tire rack. And my car isn't lowered. So I can't CONFIRM that for you.
26x8x18 would work. But you'd be sacrificing some acceleration by going with such a huge diameter of tire.
Quick Reply: OFFICIAL: Difference between SLICKS and Drag Radials
