Drag Racing Kindle Racing and Dalcorp Racing
Why Smaller Is Better
Old 03-23-2014, 09:47 PM
  #76
EXsoccer1921's Avatar
The problem isn't from having to shift from 2nd to 3rd before the line. Even if you aren't wot on the gas you're still carrying what, 85-90mph worth of momentum, it doesn't slow you down that much. But you do have a half second to drop in the 60' alone.
Old 03-23-2014, 10:55 PM
  #77
BWTIESS's Avatar
I was roughly in the 75mph range crossing the line, but what you are saying is I probably need more practice with the slicks. It was the first time I ever drove with slicks and I never successfully did a burnout.
Old 03-24-2014, 07:31 AM
  #78
bmxracerchamp12's Avatar
Originally Posted by BWTIESS
Ah you are going to make me post that? . I ran a constant 2.2 60 foot
thats doable on street tires. you should have no issues being under 2. what are you launching at?
Old 03-24-2014, 09:31 AM
  #79
dcrep06's Avatar
ouch, i pull that on streets.
x2
from what ive been told you dont have to do a crazy burnout to heat these things up and still pull 1.6s on them.
Old 09-07-2014, 12:04 PM
  #80
raver0789's Avatar
Bump this one from the grave...Cmiller8006 what was your rim make and model? Was it a 15 x 8 or a 15 x 7?
And it was a 5x110 bolt pattern correct?
Old 09-08-2014, 07:44 AM
  #81
2000Firehawk's Avatar
I'm running 15x7 rims, with the smaller M&H 23" diameter slicks, which are
really 23.5" diameter...
I'm not running tubes either...
I talked to the "tech" guys 1st at M&H, & they said that 7" rims, without tubes,
was a-ok.
I have been doing this for 3 years now, with no issues, 12.39 best ET
You can use 5x110 , or whatever bolt pattern that your Car is setup for...
Old 09-08-2014, 11:09 AM
  #82
dcrep06's Avatar
yea mine are 7in wide too im pretty sure.
SSLOW06
10-01-2015 07:21 PM
patooyee
10-01-2015 01:07 PM
toledobalt
09-03-2015 10:27 AM
brentil
11-12-2005 05:42 PM
MacG321
06-30-2005 07:14 AM
Quick Reply: Why Smaller Is Better
