5 or 6 Speed
Exactly what he said. It really depends on what kind of driving to you for a 6 speed to be better then a 5 speed. City driving, a 5 speed will be better because the lower gears are a bit longer. But highway travel, the 6 speed will be better because of what tiny said. Someone I know with a ZO6 said they can travel down the highway at 70mph in top gear getting over 40mpg....
well since my car doesn't have an armrest i use my 6th gear as a handrest. very comfortable. my car needs a 6th gear though due to my engine being high compression.
Originally Posted by tiny
more gears, higher top end, better gas mileage
No, top end is seldom found by using an overdrive gear in a modern manual transmission. There is simply not enough engine power to spin it up near the peak power of the engine as you near top end. I cannot think of any double overdrive manual transmission in any vehicle that will get a higher top speed in 6th instead of 5th gear.
Maybe, it can lead to better fuel economy if you run fast enough on the highway (careful! If you lug the engine with 6th gear on the highway without enough speed, you may be far below the optimal volumetric efficiency of the engine and you will get worse economy in 6th vs. 5th.)
A Z06 will never get close to 30mpg let alone 40
okay...here we go---since a few people have no clue as to V8 fuel mileage.
Z06 is rated at 26mpg highway. Now with the super tall 6th geat I bet that might be improved upon a little in the real world. Very common for LS1 F-bodies to get low 30's on the highway. An upside to an engine turning less then 2000rpm.
Whats the Acura do---? 3000rpm?
It all depends on the engine and the gearing. Engines that lack low end torque, i.e. most imports, require a close ratio 6 speed to keep in the powerband. The big V8's use it to improve highway gas milage, by adding an extra overdrive. My dad actually increased his 1/4 mile time by switching from a 3 speed to a close ratio 5 speed in his 55 Chevy. He had to shift more, each shift is power not going to the ground. Had the gears been spaced further apart it might have been a different story.
its true, in overdrive those things are revving so low, they get excellent highway miles but poor city miles
my b16 civic had **** poor highway mileage, maybe because i was revving at 4000 rpm going 120km/h, horrible!
Originally Posted by DC52NV
my POS acura doesn't even do 30mpg so i highly doubt a vette is close to that. lol
you also gotta remember a Z06 has 3 times the amount of tq yours has , so it can run around in 6th gear at very low rpm , which helps with gas milage
i think the new 06 Z06 was rated at 26 or 28 on the highway
Originally Posted by UtOhCop
IMO i think they should have used the 6spd from the Saab in the Cobalt SS.
Now vehicles such as the RSX-S benefit from a 6-speed purely for performance reasons. By having 6 closely spaced gear ratios, the engine can be kept in the powerband more of the time, which means better acceleration, but more shifting. For all those saying that the RSX-S gets better fuel economy on the highway than the SS S/C due to having the extra gear, you have to realize that the RSX-S actually has a higher final drive ratio in 6th than the SS S/C has in 5th gear. Meaning it cranks more RPM's on the highway than the SS S/C does, even though it has one extra gear. The reason for the RSX turning such high RPM's at highway speeds is because the engine doesn't have enough low-nd power to keep the car moving at highway speed in a taller ratio. The Type-S only produces 143ft/lbs of peak torque, meaning it's producing well below 100ft/lbs even at 2500RPM
Vehicles like the Corvette and GTO benefit from 6 speeds because they allow for an extra O/D gear when cruising. At 60MPH, the engines are only turning about 1400-1500RPM, which is practically idleing -yet there's plenty of power still available to keep the car moving without a struggle. So the first 4 gears are for acceleration, 5th is O/D gear 1, and 6th is O/D gear 2 for saving fuel and cruising
Originally Posted by Eddie
my z28 when cruising 6th gear at around 70-75 gets low 30, hard part is keeping it that speed long enough to make gas mileage good lol.
city driving is what kills a v8's gas mileage. iknow if i'm in traffic my g/m takes a plunge south. but if i'm cruising w/ no traffic at 70, i'm doing good. if i keep it below 80. i swear cruis control is my friend on this car, i cant even tell if i'm doing 100+ in this car it just climbs w/ out even knowing. cruise control will save me from a whole lot of tickets lol.
ThoR294
10-04-2015 08:44 PM
z28addiction
09-28-2015 12:03 AM
