Clutch or bearing? (Video)
So here is the run down. I have never had a problem with my car transmission wise. Today i was doing my usual just riding around town and i floored it in second up to about 5k and shifted normally through the rest of the gears (around 2.5k) When i went to downshift when coming up to a stop light it wouldnt go into any gear. So i pulled over and stopped the car, left it running and it went into gear again i drove around for about 15 more minutes ran into no problems. Only thing now is this noise.
If you listen to when i press the clutch all the way you can hear the clutch slowing down and the grinding with it. So When the car is in neutral and the clutch isnt pressed in there is no noise what so ever i can press the clutch in and there is no noise but as soon as i press the clutch in and start putting gas behind it thats when it starts.
So i took it to the dealer and they said i need to replace pretty much everything clutch wise. I crapped myself when they told me it was going to cost $2350 before tax. Can you believe that they wanted almost 750 bucks just for the flywheel. So now im going to order the GMPP upgrade kit and a ZZP flywheel. But it will still cost me $1094 in labor. Its time like these i miss having a RWD car. It took me a few hours to do a clutch install on my old camaro. But it was also no where near as fun to drive.
You can do the clutch replacement in the driveway with jackstands.
Haven't listened to the video (youtube is blocked at work), but I would caution you on taking the dealers recommendation right away. They are extra happy to always replace things to find the problem (you know since they make money on each part replaced and the labor). If you have a local performance shop go over there and ask them what they think about the sound.
So i just got back from the dealership and looking at the parts they said were bad. the bearing was definitely bad but that wasn't the only problem. Half of the rods that hold both the plates together for the clutch disk springs were broken. So the clutch was literally falling apart. So tomorrow everything is going in and then i can have fun driving the car again (after break in obviously). If i would have tried driving it more i would have most likely toasted the trans.
So from what i could find it was a factory clutch in the car It has Sach Written all over it. Also in the close up of the disk you can see all the broken rods. Im going to take it back this week and have then bleed the system again. After 200 miles its still just way too soft. I havent been able to open it up since im not at 500 miles yet but im looking forward to going into full boost with this car. Its so hard resisting flooring it with all the turbo noises lol.
