clutch pipe fitting/clutch pipe leaking
Old 03-15-2015, 07:49 PM
DarkGothic's Avatar
My Cobalt has been sitting for a couple months as I've been working on it and I just got it running the other day. I go to move it and the clutch does not disengage. I notice that the clutch pipe is angled to one side and isn't sitting straight in the hole on top of the trans. I took the metal fitting off, straightened it out, and when i tried to put the fitting back on, the clip wouldnt seat right and the fitting was loose. I believe the clutch pipe is sitting deeper in the hole. I lost all pressure in my clutch pedal and i cant figure out how to pull the clutch pipe straight up so that the clip has a place to set. The seal on the clutch pipe is still there, but i have no seal in the metal fitting and can't remember if there's supposed to be one there.
Old 03-15-2015, 08:38 PM
09CobaltSS1's Avatar
Sounds like you likely lost the nipple where the clutch pipe meets the elbow (aka distribution block).
Old 02-03-2017, 01:57 AM
Milanibud92's Avatar
Would this also cause back spray into transmission when pumping clutch ??
Old 02-03-2017, 10:41 AM
exninja's Avatar
It will certainly squirt more into the bellhousing when pumping. It's an easy check/fix.
Old 02-16-2017, 01:35 AM
thank you been fighting with this devil car for a yr now checking in morning.
05-28-2022 03:47 AM
Zharrington_2010LNF
02-08-2016 01:43 PM
biniecki
10-25-2015 02:23 PM
SSLOW06
10-01-2015 07:21 PM
nathan112i
09-30-2015 07:12 PM
Quick Reply: clutch pipe fitting/clutch pipe leaking
