Clutch wont bleed? maybe?? or somethings wrong...
Ok, so recently I noticed it getting harder and harder to shift. Thought it was just mastercylinder starting to take a dump simply because I replaced the slave clutch and flywheel roughly 5k miles ago. Well I bought a master cylinder, put her in with no hiccups and now When I vacuum bleed it, there is a continuous stream of bubbles going into the resivoir. Which is awesome accept Ive been bleeding it for hours, and its still a frequent flow of air. Sooooo im thinking I have a leak somewhere,
Symtpom 1: try manualy bleeding it the old fashon way by pumping and cracking the bleeder then closing it and releasing. Only good that did me was made the clutch peddle stick to the floor untill you pumped it up.
Symptom 2: The slave is moving back and forth perfectly fine, and no dripping or anything in the trans. (I recorded it) However the pressure plate is making a creaking noise kinda like a old door opening.
Problem with troubleshooting:
When I am pumping the clutch (my wife) I am looking for leaks somewhere. If there is air being able to enter the system then you would think you would see dripping somewhere right? Nope not a drop anywhere...
SOOOO wtf man, Im about to rip my s257 out of this, by a stock turbo and then sell the damn thing and get a new car. Sick of this clutch ****.
I've seen them leak at the line where it goes to the trans, and the vacuum pulls air past it but it seals under pressure. Did you replace that seal when you did the slave?
Also, i'm sure you don't want to hear this, but too much vacuum can fail the seals in the slave, if you pulled 25+ in/hg on it it's possible it's damaged.
Will the peddle stay up on its own? You are closing the bleeder and pulling up on the peddle, then cracking the bleeder and pushing down on the peddle correct? I had a constant stream of little bubbles when I bled it with a vacuum bleeder and was totally bled. It came from it sucking air between the bleeder and the hose connected to it from the vacuum bleeder.
Never went to 25 hg stayed around 20. The slave moves good just not enough to fully disengage. Which seals should I replace?
The bubbles I'm talking about are coming from the line that goes to the master cylinder Into the resivior. And yeah I did that, didn't see any bubbles. Also the peddle will stay up without help yes.
Justin I think joe is talking about the seals in the slave itself. Sadly I don't know if you can replace those, without just replacing the slave. Did you replace your flywheel when doing the clutch, or how many miles were on it if you didn't? What clutch setup do you have? How far off the floor was your clutch engaging before you started with this?
I'm sorry to hear that Justin. I've got way less power than you and just went with the gmpp clutch. I'm not an expert but with your setup would it be advisable to install that tob spacer? May change your engagement point with the peddle but may also help to you to not overextend. Sounds like as its wore in and got thinner, it is out of stroke.
yeti as3
02-23-2016 10:14 AM
