Finally: Organized F35 transmission fluid thread
#151
if im reading the phrasing right, which im probably not, the LSD tranny is sealed, meaning it does not need the fluid to be changed ever? i find that hard to believe. My car i just bought and it isnt a "G85" pkg but it does have an LSD dealer optioned added, i know this because the car still has the window sticker and i know to usually change the fluid at around 60k, and guess what i bought this car at,.... 60k Miles. ty if anyone answers.
#152
i doubt that it will hurt to change it. gets rid of some of the trash floating around in there, and there can be moisture buildup if the car has been sitting for extended periods of time and started /stopped for short run times.
when changing fluid its entirely possible not to get all the fluid out, but its capacity is 1.8 litres according to GM.
I ONLY use GM fluid. works for me.
#153
What happens if you use 2.2 fluid in the LSJ? I keep getting wicked grind going into R in the morning and I fear the dealer put the wrong fluid in when they did the clutch and axle seals.
#156
I replaced my tranny fluid in my IRL with Red-Line 75W-90 NS GL-5 Gear Oil, works ok.
I want to try the GM 75w-85 fluid before the winter and see if it makes a difference compared to the Redline stuff.
FWIW, I used up ~1.7L for my fluid exchange.
#157
Incase anyone cares;
I just went looking for this stuff;
The Canadian part number does differ from the US part number;
US = 88862472
CND = 88862473
If any mod/admin sees this, it might be worth adding this tidbit tothe first post in this thread - especially since the F35/LNF trans fluid replaces/supercedes the F35/LSJ trans fluid.
US = 88862472
CND = 88862473
#158
I just replaced my Redline MT90 NS fluid with the AC Delco LNF Fluid (part of the CED transmission upgrade kit), and the shifting improved a bit. Small amount, but considering it's dipping to the low 30's here in Canadia now, I'm liking the better shifting when the engine/tranny are cold.
I would definitely recommend the Delco fluid over the Redline stuff for winter usage... can't comment on if the Redline MT90 NS would protect better in the summer though.
#160
So heres the question, my I went off of a walkthrough I downloaded on clutch replacement and I swear it just said "1 bottle of AC delco MTF with OEM part number" I ordered it ahead of time, now find out I need another and my car is tied up on the dealership lift (thankfully the dealership I work at). So I cant get another quart till end of day today which is going to not get the car finished until Saturday or even Monday (not sure if they will work on it Saturday).
The parts guys here say I can use a higher weight/vis fluid like 80/90 or 80/95 non syn. Thoughts? I want to stay OEM for sure but the timeframe is killing me.
#163
#164
Not to throw a wrench on this post.... but GM part number 88862472 according to Royal purple's recommendation pdf file dated 2014 claims that their XPR 5-30 oil is the substitute for this GM part number....
I know, I just opened a can or worms for a lot of people!
#165
#171
#172
just went to GM to get trans fluid for my trans swap, got a LSD TC trans and they told me that the part number 88862472 wasnt in there system but when they looked up an 08 ss/tc the part number was 88862473, i dont know if they updated there oil or not. but looked it up and this is what it is, http://www.acdelcochemicalcatalogue....hp?prod_id=151
anyone have any info on this????
#173
DO NOT BUY from GM.
2 qts with the part number is $34 on Amazon and you can get overnight shipping for $7.99 if you have a prime membership. If you don't have prime membership sign up and try a free month and take advantage of it.
GM tried to tell me they only sell the fluid is small as milliliter bottles or something stupid and it was over $90 for 1.6 qts worth.
#174
DO NOT BUY from GM.
Seems like I read something about the part numbers being different in Canada, but don't quote me on that.
#175
US = 88862472
CND = 88862473
