(How to) make your clutch stop slipping. Find out inside.
#201
sloancallaway - get the OTTP tranny mounts. A little bit of vibration, not too bad, and no axle issues ever again.
sportredss - or whatever you rname was with the ne TC - the turbo has beefed up axles, and shouldn't have problems. Not only did they strengthen the sxles, they fixed the axle geometry issue that was the REAL cause of SC axle breakage - the one that the OTTP mounts solve. SC's and Relines DO need stronger axles - but the mounts fix it for most drivers, and 300+ whp suddenly is possible with the stockers.
Regarding this theory - bought my car with 20k. Now at 45k. Drive her pretty hard, heel-toe ALL the time (practice makes perfect). Some days my clutch slips a little, some days it doesn't. Was afraid to run this last weekends autocross n teh clutch - but it didn't slip at all with all that crazy driving! Been driving me crazy trying to figure it out.
Read this whole damn thread, went and tested a theory. Sure enough - let he idle to temp, hit the road, WOT - slight slip. Drive around for a bit shifting like I always do (3-4k every gear until at desired speed, then 5th if over 40 mph, aggressive driving) and tried it again - ran like a raped ape, SHREDDED the tires into 2nd (I run higher than normal tire pressures - around 40-41 psi front - due to cornering habits), no slip.
Car is completely stock other than the OTTP mounts just installed. Broke a couple axles drag racing, only been down teh track 4 times though as I'm more solo-II than drag. Never slipped at the track. Been autocrossed dozens of times since day 1. What little clutch slip I was experiencing is now confirmed as cold clutch related - drive her for a minute with 3-4k shifts, and I can't make it slip.
Thanks for the info - everyone - say what you want, bitch all you want, but this works.
#202
well i know this post is very old. but after i read this post back when it was released, because i was having slipping issues and thought it was the power in the stg2 was too much for the clutch, I start shifting 3k and above 3k-3.5k, after driving like this for 3 days, i couldnt wait any longer... i had to WOT and race the **** outa the car... And wow.... no more slip, infact where it usually would slip i was ready to let go of the gas, and to my suprise the damn thing kept going, all the way to my 6800 shift point.. Im even churping again in higher gears... so yes this does work and shame on GM for not telling us damnit...
they already replaced my flywheel and clutch at 5k because no one told me about this whole glazing stuff.. so thank you again... you saved me $$
#203
Interesting. I always shift at 2000 RPM in the Mustang GT. I have only about 6000 miles on it and haven't detected any slippage. It does have a V8, which requires a different shift strategy than a 4-banger on a lightweight car, but I may give it a shot on both the Stang and SS/TC (when it arrives).
#206
#208
#209
I feel like sometimes you have to let the clutch out slow, but only in certain situations. From a dead stop, you have to let the clutch out slow or you will stall. If you are coming to a red light and you are braking to slow down and push in the clutch (anticipating a full stop), but then the light turns green, you need 2nd gear and to let out the clutch slowly. I think if the clutch was let out fast in this situation, the engine could stall which could be catastrophic at speed. Happened to me today, I was behind a semi-truck making a right turn, thought I would have to stop because trucks make very slow wide turns, so I pushed in the clutch and was braking. I was crawling at less than 10mph, the truck was pulling away, I tired 1st but it would not go in so I went to second. I let out the clutch slowly and pushed the gas to prevent stalling. The engine rpms lowered below the idle for a brief time. My engine was lugging in 2nd and I was traveling too fast for 1st. I guess I was caught in no mans land. Not sure if I burned the clutch unnecessarily, I was too scared to let it out fast.
#210
also, in your example about going back into 2nd, that's why you rev match. so the clutch doesn't have to do the work.
NEVER go into 1st while you're moving, especially more than like 2 or 3mph. you couldn't go into 1st because it's a safety feature so you don't blow your tranny.
finally, you shouldn't push the clutch while breaking. If you're not shifting, you shouldn't be pushing the clutch.
#212
i have had some problems in the past but it always goes away, and i need to say i dont really think my slips at all unless i go to the track and do a lot of runs and i shift any where between 3 and 4k
#213
well heres my chance. i always shift at 2k rpms cus i feel it saves gas. and my 06 SS just started slipping yesterday. so im gonna test this theory right now i'll let you know wat happens in a few days
#214
couple things wrong here. from a stop, you're supposed to get off the clutch quickly. People use the clutch for a smooth start, but it's not the right way. I'm off the clutch by 1,000 rpms on flat ground. no need to let it out slowly. it's just glazing the clutch. If you get off the clutch and engage the gas at the right time, it will be just as smooth.
As for the poster that that post was replying to... There is no reason on earth for teh car to stall at that speed - or at ANY speed, as long as it's moving. You can leave the line in 2nd with enough gas without stalling, so why would it stall at 10 mph? Lugging a bit and not going as fast as you might like, sure - but not stalling. If you drive right, this situation should never occur. Our powerband is wide enough that there's always a proper gear to be in. If the car is bucking and trying to stall, I'd be looking for a vacuum leak.
#216
2006, ss/sc, 90k on the car... I drive it like it should be.. it's a sports car lol - have fun - you're going to have to stop at a gas station and get punched in the face by the pump anyway.. might as well enjoy the ride there right?
anyway.... no slippage when i drive it aggressive..
although I'm in the middle of replacing the rod pin now.. still 90k on those rod pins? pretty good
as much as this theory doesn't make sense.. i'm a true believer.. just read this for the first time today and it goes with my thoughts as i read about shifting and what RPM's people shift at.. and so on.. stop thinking about it.. drive the car - she'll tell you when to shift... and in this case, she likes to be whined higher than most...
great post.
great post.
#218
GM, lol.
I have no idea, anyone know where they're sourced from?
GM, lol.
I have no idea. Anyone know where they're sourced from?
GM, lol.
#219
i bought my 06 ss balt used. when i first got it the cluth released at the top. A few days later it started releasing near the floor. when i was on a road trip 6 hours away from home my clutch went completly out. i had it reaplaced and the new clutch released at the top. and a few days later it was releasing near the floor. i am curently in the middle east on a deployment so i am not driving regularly but when i get back i will try to **** no lower than 3K. i am hella concerned about my clutch going out again. I amabout to but about 4 grand in to it so i am even more worried about it going out. should i be worried?
#221
does this apply to the lnf powered balts also cause mine is slipping in 3rd 4th and 5th only cause its tuned!!! it slips about 500-700 rpms then grabs and sometimes surges... so whats up with that??
#223
im using a custom tune from backyardturbo its hptuners and thats my bad lol
he posted the tune on the hptuners web site but its bad ass
Last edited by black08SS-TC; 01-04-2010 at 07:18 PM. Reason: Automerged Doublepost
#224
@ Crawfish7162 - also, you should check to make sure there isn't any tranny fluid in the clutch housing. Sorry I forgot to mention that 5 months ago, lol. If the previous owner beat on the car hard, wheel hop can cause a crack in the tranny case that leaks fluid into the clutch. One more reason OTTP tranny mounts are made of win!
Regardless, it should take months or years to see a change in the clutch like that, not days. SOMETHING isn't right.
