how much power can the 5 speed handle - Cobalt SS Network
LinkBack Thread Tools Search this Thread
Old 10-10-2005, 06:52 PM   #1
how much power can the 5 speed handle and what are the week links in the drive train
turbo joe is offline   Reply With Quote
Old 10-10-2005, 07:41 PM   #2
Images: 10
which 5 speed, the 2.2 and 2.0 have different trans
wikkymaster is offline   Reply With Quote
Old 10-11-2005, 05:54 PM   #3
The Trans that comes with the ss supercharged cobalt
And what are the limits of the related components
Old 10-11-2005, 06:02 PM   #4
Images: 2
Along the lines are there any gm junkies that can tell me how much hp the ss s/c engine can handle b/f dying, and what the specs are 4 the clutch and tranny with how much torque they can withstand. I am going to put my ss up to about 300 hp when all is done and I was wondering if I put slicks and a stage 2 clutch in it will the trnny be alright?
glockglade is offline   Reply With Quote
Old 10-11-2005, 06:59 PM   #5
Images: 1
The getrag GM 5 speed has been used in applications that have handled well over 400HP, if you want proof, check out the V8 Fieros. Other then that, we don't konw the specific limits of the SS tranny.
Here's a link that has some stuff on the getrag power limits
http://www.v8archie.com/faq.htm
Quote:
With the ‘86 thru ‘88 6 cylinder 5 speed transmissions, I have used engines rated at 460+ H.P. (One even had an additional 200 H.P. dual quad carb. NOS system on top of a 460 H.P. 383" Chevy stroker engine) With no failures yet.
And that's with the older getrag 5 speeds
VaMP is offline   Reply With Quote
Old 10-11-2005, 10:00 PM   #6
thank you
Old 10-12-2005, 12:08 AM   #7
Domestics Pwn
ExHondaMan's Avatar
Images: 2
I thought the SS/SC did not have the getrag 5 speed....
ExHondaMan is offline   Reply With Quote
Old 10-12-2005, 12:09 AM   #8
Images: 10
it doesnt
Old 10-12-2005, 12:18 AM   #9
Domestics Pwn
ExHondaMan's Avatar
Images: 2
Ya uses the saab sourced F35 transmission... Only information ive really found is Borg-Warner is making the synchronizers
Old 10-12-2005, 12:32 AM   #10
Images: 1
Ahhh I was under the impression that it had the getrag. Thank you for clearing that up.
Old 10-12-2005, 12:54 AM   #11
So the trans in the SS S/C is a Borg-Warner unit???
If it is, then thats good to hear - because the J-body guys always seem to be having problems with the Getrag and Isuzu units in their cars. The Isuzu's have weak synchros and aren't very strong, whereas the Getrags tend to have problems with gears grinding (probably synthros) and other annoying and costly mechanical issues. Borg-Warner, on the other hand, has a pretty good reputation as far as I've heard
wesmanw02 is offline   Reply With Quote
Old 10-12-2005, 01:49 AM   #12
Domestics Pwn
ExHondaMan's Avatar
Images: 2
Its not a Borg-Warner Trans... Its a Saab trans... BW makes the synchros for it, thats it...
Old 10-21-2005, 11:39 PM   #13
importkiller's Avatar
Images: 8
so....i talked to some GM techs and they say the 5sp get can handle up to 500 hp with no mods, but the clutch is a different story i would change that before you hit 200!....as for the ss/sc tranny i have no info as yet.
importkiller is offline   Reply With Quote
Old 10-21-2005, 11:46 PM   #14
avro206's Avatar
Images: 141
Almost any transmssion can handle a big increase in hp/torque but the question is for how long???
I would suspect that GM does durability tests and likely a stock trans can last over 100,000miles behinda stock engine. Add some power and that would go down.
avro206 is offline   Reply With Quote
Old 10-21-2005, 11:52 PM   #15
Images: 1
Yeah but GM doesn't seem to be BSing around with the Cobalt SS. I imagine, depending on the type of clutch, that it could handle power that would exceed the limits of internals - safely.
Old 10-28-2005, 12:52 AM   #16
I could use some additional help on this transmission in specs if some GM engineer is reading this forum.. Please PM me...
I will share what I have read...
The Ion and Cobalt have the MU3 / F35 GETRAG. See this webpage for details of specs
http://www.fastfieros.com/NEW_manual...ion_ratios.htm
The transmission comes from the Saab product line under the destination of F25. This transmission has a LSD from Quaife already available and was adapted to the F35. The F25 also has a 6 speed upgrade, but Quaife indicates this will not directly interchange to the F35.
The F35 has a GVW rating of 5000 lbs. This is extremely high for a transverse transmission. GM perpared the Cobalt and Ion for the Stage 1 and 2 upgrades long ago. The warrantty is good even with the ordering of a LSD in the 06's.
The F35 is a really good transmission. I just hope the syncro's can hold up better than the 282, and 284 GETRAGs did.
Loyde
FastFieros is offline   Reply With Quote
Old 10-28-2005, 02:32 PM   #17
Images: 1
Quote:
Loyde
Do you know the rating for the getrag in the Fiero so we can get a good estimate of what the F35 might handle?
Old 10-29-2005, 12:05 AM   #18
I'm old school
Halfcent's Avatar
Images: 480
I love hearing about what people have done in the real world with real applications, but I'm much more of a specifications kind of guy. Here' is what GM publishes about the MU3.
Stats
They say the max input torque is 200 ft/lbs, which is surprising, because the automatic can take more then that, and the SS engine already produces close to that amount. With stage upgrades, the car will certainly produce greater then 200 ft/lbs, and they will still warrenty the powertrain. So thats really interesting to me.
Halfcent is offline   Reply With Quote
Old 10-29-2005, 02:01 AM   #19
Images: 9
I read it as the gearbox can handle 258 lb-ft of torque.
myoshizawa819 is offline   Reply With Quote
Old 10-29-2005, 02:17 AM   #20
No, but it cant handle a 3800SC with about 350HP...
The data is too old for the 282 and 284 to find. Maybe in some old sales documents the info might be there still. I have looked online a few times.
The Diff housing area on this F35 is huge. Well beefed up casing structure.
I just got my LSJ and F35 today. I removed the transmission and took a peek at the clutch and pressure plate. The clutch disk is large and thick for a stock unit. Its still a LUK disk and pressure plate however. They typically produce GM's factory installed stuff. I see the hydualic release bearing must have needed some extra "feel" so they installed a secondary dummy spring plate. The release bearing worked very easy, so surely it is not for helping the release bearing to return to home position.
This disk looks like the typical OEM style, slip it to many times and it will be done..
The flywheel is heavy and thick. I see it is neutral balanced. Thats nice so lighten ones just need equal holes. The flywheel can handle a 9 11/16th disk with modifications. I use this size in the 3800SC engines. McLeod makes a disc in cinder iron that can handle 550HP and is still very streetable.
Loyde
Old 10-29-2005, 03:04 AM   #21
Images: 175
So wait, the Cobalt SS/SC's clutches are only rated at 200ft/lbs? Isn't that well...kind of a bad decision on their (chevy's) part?
memphisr24 is offline   Reply With Quote
Old 10-31-2005, 01:41 PM   #22
Yeah i just put the 3.0 pulley on my car and my clutch slips when i shift into 2nd alot...so iam guessing that it can only hold up to 200hp
Knightrider22 is offline   Reply With Quote
Old 10-31-2005, 02:04 PM   #23
Eveything you need to know about how much power the tranny,drivtrain, engine parts, etc. Are in the new GM build book. It is great.
GotBoost? is offline   Reply With Quote
Old 10-31-2005, 11:21 PM   #24
I'm old school
Halfcent's Avatar
Images: 480
Quote:
Well, uh, not really. The build book does not have specifications for the stock transmissions. You can obtain that data from GM here.
There are other places too.
Old 11-01-2005, 12:10 AM   #25
Images: 175
DAMN. Now i'm going to have to spend $500 on a new clutch and another $500 for labor
Thread Thread Starter Forum Replies Last Post
New steering rack Solaris99 08-10 SS Turbocharged General Discussion 27 08-31-2016 08:45 PM
stock lnf clutch Zharrington_2010LNF 2.0L LNF Performance Tech 21 02-08-2016 02:43 PM
Let down the cobalt community on this one. RaginChopsuey War Stories 16 10-27-2015 02:27 PM
For Sale Forged rods (5.565" short version) for Chevy 400. Jesse Stuff 0 10-01-2015 06:47 PM
$90 @ Streets of Willow October 10-11 2015 Extremespeed South Pacific 0 09-29-2015 05:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
