KY Clutch - Official Release!
#251
#253
Need sum help buying a new clutch want this clutch from what people are saying bout the clutch, I hav a stage 4 clutch masters with flywheel. Do I need a new flywheel or can I reuse this one? Also how does this clutch compares to the Spec stage 3+? My boy has one on his coupe an that thing is damn near flawless..
#263
Two questions, would a lightweight flywheel not be recommended on my 2.4? I would like to use one being NA but if it's not recommended with this clutch I won't do it. Also would breaking in the stage 2 clutch NA be a bad idea with only around 200hp then later going turbo?
#264
Break in would be idea with it being N/A and then going turbo, it will help the break in process, so you are not as likely to abuse it
#267
Here is a more (key on) Of why not to go with a lightweight. If the car is a dd, the crankshaft will have a easier rotational mas since there is less weight. So therefore the car will hold its revs longer and may pop up a po336 because the crank sensor. If the car isnt a dd it is better to go with a lighter flywheel because itll hold its revs so when racing its easier shifting. But they do cause issues wiothin the ecotecs for dds!
#274
Ok. So my '08 SS/TC is shifting rougher, and it's harder to get into 1st and 2nd gear. Off the back, i'm thinking new clutch. If I do replace the clutch, I want to replace the flywheel also. Is it better to just get a new aluminum flywheel or just resurface the one i have? Can I get a PM on a clutch? I'm not modded yet, but I do plan on throwing things like an intercooler, full exhaust, CAI, BPV, etc... simple upgrades. My SS/TC is my DD also so I will be going thru Mickey D's n encountering traffic.
#275
2. Get a KY Stage 3 clutch, best price is on our site.
Anything else let us know.
