My DriveTrain Upgrade...
Well in about a month i will be getting a drivetrain upgrade including
CMfx400-6-puck
Fidanza Flywheel
Driveshaft Axles
installed for $2250.00
I was wondering, what mounts should i get for them to throw on in the mean time?
Thanks
CMfx400-6-puck
Fidanza Flywheel
Driveshaft Axles
Thanks
I have the ZZP engine and tranny mounts and both work very well in preventing wheel hop. Mine is practically gone actually. The only downside would be the vibrations, but I can live with that.
Originally Posted by CobaltBurst
you can get a 2.2 fidanza. Basically weighs less than the stock flywheel, = easier for the engine to turn = rpms dont fall as fast.
Originally Posted by wdsoccer
so it will work on a 2.2l auto? does it improve hp?
This has nothing to do with an auto. Automatics have a torque converter, manuals have a flywheel and clutch
since it is lighter it spins longer i believe it revs fast as hell i can tell u that i had one on my cavy....
i dont think it will have any negative effects in drag...... im prettysure it spins longer, keeping the rpms up during shifts on drag... not positive though
I'm old school
There are in fact flywheels in automatic trans equipped cars. What do you think the torque converter attaches too? It is however a different flywheel. So to answer the question, NO, you can't use it on an auto.
The flywheel is a large disk mounted to the output side of the crankshaft that does 2 things. First, it gives you something to bolt your transmission to. Second, it provides rotational mass to keep the engine revolution speed smooth through the 4 stroke cycle.
Originally Posted by harrington
In an auto its called a flex plate, not a flywheel.
Correct! Autos do not have a flywheel at all.
They have a flex plate with a ring gear on it.
Later
Here's my question...What is the difference between 4 puck and 6 puck, and which would be better?? Or is a, depending on it's use type choice?? Sorry to thread steal..
