Southbend slips
Southbend slips
After my engine build I put a brand new southbend clutch and pressure plate in. Stage3. I however forgot to get the flywheel resurfaced, but can't imagine it would slip that bad. it's slipping really bad. I have to drive extremely light on the throttle, and I mean extremely light to get it to go. What could it be? Was installed correctly
If the pressure plate wasn't prepped correctly (which is wasn't) you have successfully embedded oil in the disc as a result. Plus, judging from how much slippage you had, there's a good chance you glazed the disc on the flywheel side considering the flywheel never had a fresh surface for the disc to bed to. I wouldn't even consider reinstalling that disc, but that's just me. It aint my car nor a custom's of mine, so I honestly could not care less. Best of luck to you.
