Trans Fluid???????
Old 05-02-2008, 01:28 PM
FASTL61's Avatar
Trans Fluid???????
ill keep it short and sweet.what kind of trans fluid does a 07 cobalt ls take..5 speed.i wanna swap fluids
Old 05-02-2008, 01:42 PM
XgunsmokeX's Avatar
use royal purple
Old 05-02-2008, 03:35 PM
FASTL61's Avatar
ya but what type.gear oil. motor oil.dexron 3 mercon atf+4 water?lol just kiddin i need to what type!
Old 05-02-2008, 04:27 PM
XgunsmokeX's Avatar
i don't know that info since i am a atuo, but go to the part store ask if they got royal purple products and tell them ur make and model, thats what i do at napa,autozone etc
Old 05-02-2008, 04:29 PM
FASTL61's Avatar
shows up na for 07. 05 comes up with dex 3 but i dont know if itchanged for 07 and i really dont wanna put the wrong **** in there
Old 05-02-2008, 04:33 PM
BigTizzle903's Avatar
75w-90 gear oil
get royal purple synthetic or amsoil. when i go to order my regular motor oil from amsoil im getting their gear oil as well. i would buy 2 quarts of it but your probably only going to use like 1.75 of it.
Old 05-02-2008, 04:35 PM
FASTL61's Avatar
okay your positive its gear oil and not dex atf?i looked up an 05 at work and it said dex3 for all trim types
Old 05-02-2008, 04:37 PM
yes, ATF stands for Automatic Transmission Fluid, which as you said you are not an automatic.
Do a search, I asked the same question a while back and you need to use 75w-90 gear oil for a 5 speed and your going to use a little under 2 quarts. and if im not mistaken, the drain for the gear oil is in the drivers side front wheel well somewhere
Old 05-02-2008, 04:39 PM
FASTL61's Avatar
true but i have heard of standards takin atf...i mean **** the honda trannys take 10w-30
Old 05-02-2008, 05:11 PM
big_stu's Avatar
All transmissions in the 05-08 2.2L and 2.4L Cobalts require Dexron 3. If you go to GM they are now selling Dexron 7. Its reverse compatible. It is the proper fluid for the 5 spd getreg and the auto transmissions. It's 1.7 litres / 1.8 quarts to fill. Stick with what the manufacture reccomends.
Stu
Old 05-02-2008, 05:19 PM
FASTL61's Avatar
bad ass cool i thought so.if i use a synthetic would that help out alot?when i shift to 2nd at high rpm it has a little grind.low rpm is smooth as a whistle and every other gear is perfect any rpm.any suggestions?
Old 05-02-2008, 06:18 PM
Stu
is the dexron that gm sells synthetic or non synthetic? if its not then im just going to stick with my plans on getting amsoil
the grinding could be bad synchros
Old 05-02-2008, 07:57 PM
FASTL61's Avatar
started doin it with 5,000 miles i know its synchros but i dont wanna take it in yet lol maybe later on this month
Old 05-02-2008, 08:02 PM
jeremie's Avatar
i'd use water.
Old 05-02-2008, 08:11 PM
Cobalt(312)'s Avatar
Word to the wise i've been down this road before if you change your trans fluid consider your warranty as far as your transmission goes voided, they won't work on it. That was one of the big questions I had to answer when i brought my car in awhile back to get the transmission fixed when i asked him what if i swapped tranny fluids the guy said well then its no longer covered.
o and i brought mine in and the tranny had to be rebuild and it had like 40 problems with it because i had to drive on it because they wouldn't take it in until it was convinent for them
Old 05-02-2008, 08:12 PM
FASTL61's Avatar
Originally Posted by jeremie
i'd use water.
haha lmao thats what i was thinking
Old 05-02-2008, 08:26 PM
rockkrawler628's Avatar
dude.. try searching... i can't believe nobody said it already.... theres alot of posts about trans fluid and even a poll..
Old 05-02-2008, 08:50 PM
silverfae7's Avatar
GM service info and the owners manual say for the 07 2.2 and 2.4, manual trans fluid part #88861800 which IS NOT ATF. The 05 & 06 2.2 & 2.4 take dexron 3 ATF. It was changed in 07. The 2.0 for all years takes part #21018899.
Old 05-03-2008, 12:35 AM
so the 05 and 06 MANUAL transmission cars take AUTOMATIC transmission fluid???
Old 05-03-2008, 12:38 AM
FASTL61's Avatar
yup yup
Old 05-03-2008, 01:16 AM
outtamymind's Avatar
its actually called mtf not atf for the manual transmission's and i just put the synthetic mtf that the ss/sc use in my 2.4L cost's a little more but worth it if you ask me.
Old 05-03-2008, 01:25 AM
FASTL61's Avatar
do you fell diff. at all?with shifting or anything?
Old 05-18-2008, 06:33 PM
so did you end up switching yet? i just picked up some synthetic mobil 1 from autozone for $8 a quart
Old 05-18-2008, 09:38 PM
i did a little nothing huge but a little bit.
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
01-12-2016 12:01 AM
Tupp
09-29-2015 11:07 PM
09-27-2015 08:53 PM
Quick Reply: Trans Fluid???????
