transmission bolts
Old 02-16-2016, 12:54 AM
exninja's Avatar
Originally Posted by tomj77
mine had that bolt it is the same size, but it uses a 13mm wrench. unless the shop who put my clutch in used a 13mm instead of 18.. the head is 13mm the bolt itself is the same size and thread as the rest of the 18 mm bolts
Very possible they put an extra bolt in then.
Old 02-21-2017, 01:32 PM
Dennis461's Avatar
Old thread, brought back to life.
Took me two hours to find the last bolt on my 2006 Cobalt LT with 2.2 motor.
NINE bolts in all through motor to tranny.
Marked them with a black X in photo.
I could not have done this without taking the exhaust manifold off.
[/QUOTE]
Old 02-21-2017, 01:57 PM
royce777's Avatar
^ I believe if its a auto it has more bolts that hold the trans to the block.
Old 03-01-2017, 09:50 PM
63 Nova SS's Avatar
Yep
Old 03-16-2020, 03:13 AM
Jstead93's Avatar
Cant figure out how many bolts hold the transmission to the engine. I have an 06 ss. 5-speed manual. Front wheel drive. 2.4. I found 6 bolts cant find the rest
Old 03-16-2020, 08:28 AM
Did you get the one behind the starter?
Old 03-16-2020, 11:24 AM
Rattlesnake Race Shop
USMCFieldMP's Avatar
Or the one under the t-stat housing? It screws in on the block side, not the transmission side.
05-28-2022 03:47 AM
SSLOW06
10-01-2015 07:21 PM
Tupp
09-30-2015 08:18 PM
Iceberg
09-29-2015 12:33 PM
Iceberg
09-28-2015 01:31 PM
Quick Reply: transmission bolts
