461whp/484wtq - EFR LNF
A lot really depends on how hard you plan on pushing the turbo. Past 25psi you're likely to need either the intake came with upgraded pump lobe, or 5th injector to avoid massive fuel rail pressure dips. Only logs from your tuner will really tell the big picture for your answer. I personally went the 5th injector route with my car. Granted most don't accept this is a viable long term solution, but I've had very good results with using it in the countless logs I ran on my engine. Some also claim that there's no way to accurately supply fueling to each individual cylinder. While this could possibly be true, until I see actual hard data to back this up I stand by my own results. Not to mention, try telling that to anyone making big power on a carb engine. The 5th injector is a similar principle as a carbed engine (central manifold fueling), just with more control than a carb.
Numbers are STD corrected. SAE corrected it would have made around the same whp as your car did SAE (around 445 whp and 465 wrtq) and yours did not need E-47 or a 34 psi boost spike at 4000 RPMs.
