Dyno Results Dyno pictures, videos and dyno results.
Cobalt SS LSJ 2.0 SUPERCHARGED BREAKING THE 400 WHP BARRIER!
Old 09-30-2016, 02:52 PM
  #76
South Central *********
JapEatr's Avatar
curious on the gear ratios as well
Old 10-01-2016, 09:36 AM
  #77
Originally Posted by 100% METH
Thanks guys
Going back for more now
12.5:1 2.4 block is going in now
Also swapping the 4.17 final for a 4.41
Lawd those gears would be ridiculous if you werent revving to 10
Old 10-03-2016, 07:10 PM
  #78
100% METH's Avatar
Final Drive 1 2 3 4 5 R
4.17 3.58 2.02 1.35 0.98 0.69 3.31
2005–2008 Chevrolet HHR
2009-2010 Chevrolet HHR is 3.95:1 FDR
4.41 3.58 2.02 1.35 0.98 0.81 3.31
2002–2007 Saturn Vue
So basically... taking the 4.41 final out of the vue transaxle, and swapping into the f23 trans from the 05-08 HHR.
Old 11-20-2016, 09:55 PM
  #79
dannysauer's Avatar
Any way we can get some info on what's involved in to changing to the f23
Old 11-21-2016, 06:26 PM
  #80
100% METH's Avatar
F23 trans
f23 driveline + shifter
f23 front mount
shave some material off where the f23 comes into contact w/ the lsj thermostat housing
go into hptuners, and change the trans setting to adjust for the new gearing.
That's about it
Old 12-04-2016, 11:32 AM
  #81
no_ss's Avatar
How much did you port the head? Sounds pretty cool. 9000rpm is crazy
Old 01-19-2017, 03:05 PM
  #82
100% METH's Avatar
No exact measurements on my part
But the intake side is opened some, and the exhaust side quite a bit
It's opened up past the EGR holes on each exhaust port IIRC... would need to pull pix
Old 01-19-2017, 03:24 PM
  #83
Isaac Lewis's Avatar
It's official! The 400whp barrier without N20 on a 2.0 LSJ has been passed!
Cobalt SS SC 423hp - YouTube
Original Owner - 07 Cobalt SS Supercharged
Engine/Valvetrain:
- Tjolley built Forged 11:1 Compression 2.0 LSJ
- Tjolley Ported Head | ZZP Stage 3 Cams | Supertech #75 Springs
- ATI Overdrive 6.78" | Aux Chain delete | Balance shaft delete | Oil Mains deburred
Intake/Exhaust:
- OTTP 3.5" SS Cold Air Intake | LS4 Throttle Body
- OTTP 1.75" - 3" Long Tube | 3" - 2.5" Catless Mid Pipe | 2.25" Borla Catback
Power Adder:
- TVS 1320 | 2.8 Pulley
Cooling:
- Oversized Ebay Special Radiator | 160* F. Thermostat
- Stock Intake Manifold | Stock Endplate | Tjolley custom made Griffin front mount heat exchanger
- Electric Water Pump
Transmission:
- 07 HHR F23 Transaxle
Final Drive - 4.17
1st - 3.58
2nd - 2.02
3rd - 1.35
4th - 0.98
5th - 0.69
Reverse - 3.31
FUEL:
- 1200 CC FIC Injectors
- Return style | Boost reference
- AEM 320 LPH Fuel Pump
- E85
STOCK THROTTLE BODY / STOCK LSJ INTAKE (AIR BOX MOD) VS OTTP 3.5" INTAKE & LS4 Throttle Body
im really surprised by how far off those hp/tq numbers were. why do you think that is?
Old 01-19-2017, 04:07 PM
  #84
HP= (Tq*rpm)/5252
Old 01-19-2017, 04:12 PM
  #85
Slobodan Milošević
07blackg5's Avatar
Street Cred= (peakhp+peaktq)/******** Diameter(inches)
Slowbalt2000 (01-19-2017)
Old 01-19-2017, 04:13 PM
  #86
can you always use that algorithm to find out how much HP a car makes?
Old 01-19-2017, 04:14 PM
  #87
Its the definition of hp, its a calculated value
Old 01-19-2017, 04:16 PM
  #88
ok. this is the fist i have ever heard of it.
Old 06-29-2017, 12:40 AM
  #89
315SS's Avatar
good work!
record won't last long though unfortunately, going to be putting this in my rear veiw next dyno session 😉🤔🤐🏎
Old 06-29-2017, 12:44 AM
  #90
Thats what they all say
advise (06-29-2017)
Old 06-29-2017, 05:27 AM
  #91
315SS's Avatar
hm. Fortunately I can clear up the confusion being I know who they are, they are the Know all, never done's. And yes that is what they all say, but I'm not they and they aren't I, so when I say this it's different than when they say that.
😎How'd I do👌🏼👍🏼
to correct myself, not the next but the first dyno visit with my car, 20 months & nearly as many thousands as months later 😇🤐😘
Old 06-29-2017, 11:19 AM
  #92
advise's Avatar
😎How'd I do👌🏼👍🏼
my motors going in this weekend
2.0 pulley or bust
Old 06-29-2017, 12:27 PM
  #93
315SS's Avatar
2.0 pulley or bust
I like your style!
I just dropped my new motor, transmission & clutch masters twin disk & Billet flywheel in last night. After work all that's left to do is bolt on blower, Intake & fill up the Coolant & hopefully past this winters investments fire right up without issue 🏎🤞🏼😊
Currently on a 2.7 pulley & 150 wet shot but that pulley size could be dropping fast, depending on the whp w/o the bottle,...just to try and join the 400 Nitrous free club 😉
Old 06-29-2017, 06:49 PM
  #94
Slobodan Milošević
07blackg5's Avatar
flow mods>pulley down. you should be able to hit 400 without going below a 2.7
Old 06-29-2017, 07:17 PM
  #95
315SS's Avatar
ha, I was just breaking *****. A number on a sheet of paper and "bragging rights" towards people I don't know isn't worth a new motor to me.
I litterally have installed every flow mod built for these cars & some that aren't even sold for these cars I designed & fabricated myself. Only area it'd be possible for me to gain any type of flow is the ottp 2" primary - 3.5" collector header & down pipe. Other than that literally maxed out everywhere
advise (06-30-2017)
Old 06-29-2017, 07:44 PM
  #96
Slobodan Milošević
07blackg5's Avatar
headwork?
Old 06-30-2017, 09:37 AM
  #97
advise's Avatar
cnc race port
Old 06-30-2017, 09:45 AM
  #98
advise's Avatar
excited to see all these tvs builds
Old 06-30-2017, 01:18 PM
  #99
315SS's Avatar
headwork?
yessir,
Old 07-10-2017, 02:45 PM
  #100
100% METH's Avatar
Good luck guys
Quick Reply: Cobalt SS LSJ 2.0 SUPERCHARGED BREAKING THE 400 WHP BARRIER!
