The Official Dyno Thread 2015
#194
Yeah it does! 09cobalt tuned me up a little rich bc we thought my bypass solenoid was the issue, so when i went to crimp the bypass hose when testing it wouldnt run too lean. But it was okay Either way I'm sure on the E50 and a 2.8 with a good tune I will be into the 3's
#195
I realize this is a couple weeks old. It's in the tune. Vehicle stock needs to be above 62mph to control trans downshift, but you can zero it and max out the RPM limit under the "Trans Diag" tab in HP Tuners. Then you can command it to stay in the same gear in the VCM scanner. I found this out the hard way.
#196
#198
2008 cobalt ss lnf. Stock k04. 349.21/399.66
Dyno jet. Hustler performance dyno tuning downey ca. Tuned by a member on here.
Mods: I/IC/DP/E/T/UPPER CP/K04/E47/GM1S
Let me know if anything else is needed.
