Dyno Results Dyno pictures, videos and dyno results.
Staged07SS finally goes to the dyno!
Old 10-30-2014, 07:07 AM
  #101
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by LNFTX
Have you ever had the H 62 apart to take a look at how good of condition the rotors are in?
I never took it apart. Didnt need to. It only had some dyno miles on it from Intense, and a few driving miles from blackmagic.
It was pretty much a brand new supercharger when I received it. The rotors were mint. It didnt even have a spec of blow by in the inlet.
I've had the blower off my car pretty much every year since I installed it, and the rotors and housing are still like the day I installed it.
Old 10-30-2014, 11:54 AM
  #102
user 72239's Avatar
Nope. The H62 is a 1L blower.
It is unique because it still has 3-lobe rotors but they are twisted double the angle of the M62 rotors.
Hey man.... you should be banned for a week.
teehee
Don't ban me bro!
Old 10-30-2014, 11:56 AM
  #103
Administrator
Administrator
Staged07SS's Avatar
Don't ban me bro!
Old 10-30-2014, 11:59 AM
  #104
100% METH's Avatar
Old 10-30-2014, 12:02 PM
  #105
yellow dragon's Avatar
Sweet stuff, wicked numbers and nice build.
Old 10-30-2014, 12:03 PM
  #106
Administrator
Administrator
Staged07SS's Avatar
Thank you sir!
Old 11-04-2014, 10:25 PM
  #107
DarkChild's Avatar
Seeing your build makes me wish I had stuck to GM specs as well. Smaller pulley isn't always better.
Old 11-05-2014, 07:15 AM
  #108
Administrator
Administrator
Staged07SS's Avatar
Agreed!
Old 11-05-2014, 10:52 AM
  #109
InfraRedline's Avatar
Agreed!
I wouldn't necessarily say that. There are diminishing returns with a smaller pulley, but you would no doubt make more power by dropping pulleys. I understand why you have the pulley you do, and why you want to keep it, but dropping pulley sizes would net you some gains, there is no way around the fact.
Old 11-05-2014, 04:52 PM
  #110
Olybaltss's Avatar
teehee
made me lol at work
Old 11-06-2014, 07:16 AM
  #111
Administrator
Administrator
Staged07SS's Avatar
I tested many different pulleys on my car. None of them gave me enough reason to not utilize the GMRS3 pulley. I know the 42's limit me to an extent, but I'm not going for dyno queen kinda power. Once I throw the 50 shot at her, I will be more than happy with the power.
Sure I could get larger injectors and pulley down and make some additional power and torque, but at the cost of some loss of efficiency.
My main point is, you can make good power with a larger pulley. Cramming more air into an engine that cant utilize it properly is not the answer (as many do on this site). A ported head and cams is a much better modification than throwing a tiny pulley on, and I know you know that.
Old 11-06-2014, 10:56 AM
  #112
I forget you have 42's. But on the next point, of course you will sacrifice some efficiency as you raise boost, especially on a blower, but if that's the case then we should all be running 3.35" stock pulleys. I hear what you are saying, and am not arguing with you. I agree that a ported head is about the best thing you can do for these cars, but at the same time I wouldn't personally discourage someone from using that ported head to more efficiently take advantage of a pulley drop. You have probably the best balance of efficiency and power of any pulley there is on your car, but for the people that wanna push a bit harder I wouldn't tell them that its not worth dropping sizes. I picked up ~12-15whp/15qtw by dropping from a 2.9 to a 2.7 5 mins apart on the dyno after already making about 10 runs on the 2.9, and then picked up 3mph in trap speeds with the same 60' time. Granted that was on the TVS so the efficiency doesn't drop off quite a fast, but it shows there were gains to be had. On a smaller blower the returns will be smaller of course. I personally run a 2.7 on my M62 car with a ported head and cams on E85, but fuel has a lot to do with my recommendations as well.
Basically what I am getting at it, I understand what you are doing and respect it, but some people want to squeeze it all out, so to be fair I wouldn't turn someone away from taking the dip in efficiency to squeeze some more power out. We all have different goals and build different setups.
Old 11-06-2014, 11:51 AM
  #113
Administrator
Administrator
Staged07SS's Avatar
I'm not trying to turn people away from small pulleys, nor am I claiming they are a waste of time... I'm simply trying to get people to look at every aspect of a build before they just go slap a small pulley and larger injectors on their car.
Everytime I see a build the answer for making power is "drop that pulley down", when in reality that person may not even be able to efficiently utilize the extra airflow.
I also wanted to make it known that even a 2.9 or 3.0" pulley can make decent power. That is all I'm trying to help people understand. That's why I say a small pulley is "not always" the answer...
It is not intended to stop anyone from doing what they want with their car. It is merely something to think about. Also, I know you arent trying to argue. I'm just trying to clarify my point is all.
Old 11-06-2014, 12:25 PM
  #114
Now that there is no confusion for us or anyone reading and points have been made clear, I think some good info has been shared on both sides of the matter. There isn't enough discussion like this on the forum anymore.
Old 11-06-2014, 12:53 PM
  #115
Administrator
Administrator
Staged07SS's Avatar
Old 11-06-2014, 01:05 PM
  #116
Got Bewst?
Bluelightning's Avatar
I totally agree. I miss the discussions.
Old 11-06-2014, 04:49 PM
  #117
Olybaltss's Avatar
This is the best example i've seen on the forum in awhile of explaining your perspective/POV without somebody turning it into a cockfight and winner versus loser.
Thanks for the faith in humanity lol, and the knowledge guys.
Old 11-06-2014, 06:17 PM
  #118
gotta agree there!
Old 11-07-2014, 07:10 AM
  #119
Administrator
Administrator
Staged07SS's Avatar
You're welcome!! Infra knows his ****, so he made lots of valid points, as did i.
I knew him and I werent arguing but trying to get our points across on the subject of pulley size.
The battles usually occur when you get two people that don't know what they are talkng about, lol.
Old 11-07-2014, 02:59 PM
  #120
ItalianJoe1's Avatar
I made plenty of power on my 2.8/42's setup and I always recommend that to locals here because of the hot weather we see 11 months out of the year. The lower pulley sizes just don't allow you to run any timing on pump gas and you can't make the power up top, just a little more torque in the mid range. When I do the new cobalt build I probably won't go any smaller than a 2.9" pulley because i'll be overspinning the blower anyway at that size with the RPM's i'm shooting for and it won't gain me any noticable power.
Old 11-07-2014, 07:23 PM
  #121
Powell Race Parts's Avatar
^^^ this. Hey Joe send me an email I sent a Miami fellow over to you today...cheers
Old 03-24-2015, 11:24 AM
  #122
ebristol's Avatar
Originally Posted by 100% METH
Didn't Brian unofficially make somewhere in the ball park of 320whp on the h62?
And 600whp unofficially with a turbo and gutted M62 as IM.
Originally Posted by Area47
I did.
via Imgflip Meme Maker
Hey guys, I finally got to dyno my most current setup.... 299whp 242wtq!!
Awesome! You deserve a bump. When your ready for that next step.
When your baby screams and whines give it the bottle...Nitrous Trifecta GMS3 - Saturn ION RedLine Forums
All BS aside there is 20-30whp left in that setup with a smaller pulley and E85. AT LEAST! Not to mention to the TQ gains with a smaller pulley...
But you did it your way and I give you credit for that.
Old 03-24-2015, 11:27 AM
  #123
Administrator
Administrator
Staged07SS's Avatar
Thanks man!!
Next step is hooking up my 50 shot. Other than that she is complete.
Old 04-14-2015, 09:32 PM
  #124
RoelSS's Avatar
Jeff!!, Congrats on those numbers I knew you'd have great results and this proves it right.
Still have the cobalt, on the same mods, and running great! (128k miles and passes smog easily). Actually getting to ready to celebrate our 10th anniversary lol!
Old 04-15-2015, 07:12 AM
  #125
Administrator
Administrator
Staged07SS's Avatar
Roel!! Great to hear from you, and thanks!!
Glad to see you still have the car. Keep in touch man.
Quick Reply: Staged07SS finally goes to the dyno!
