Term2 Tune 91octane LNF record?
Got Bewst?
Lol yeah that 91 does not like much timing at all. The OPs car is only running 12* max timing at 24-25psi max boost but it is quite a bit faster than when we started at 22.5-23psi and 13*. The secret in this case is mostly the wg tables that's why it holds torque a bit longer than most which is how it made 351whp with only 376 wtrq. If you spin the little K04 turbo up too hard and fast it will make over 400 wtrq but it falls off faster but get it ramped in just right and it holds the torque longer.
True, but you have to admit that has to be a bit of a high reading dyno right there. 350whp out of a setup pushing only 35-36lbs/min is a bit of a stretch.... short of e47 or e85 of course. It's all relative to the dyno.
He's on 91 though not E-47 or E-85.
#36
True but it made only 303 whp with 358 wtrq same dyno on a 23psi trifecta tune. He should have thrown his stock tune in and dynoed it first or after his tuned pull but I didn't know he was going so I couldn't tell him to. Based on the Speed3 and Civic Si dyno results it seems within range to me. He made 100 whp more than the Speed3 which was bolted and tuned on 91. Dynojets normally read all about the same as long as the weather station is not messed with.
#44
