15 inch sub anyone?
15 inch sub anyone?
Hey I'm wondering if anyone has a 15 inch sub in their cobalt and I want to know a bit about the box they have it in..
I really want to get one 15" FI BL and build a nice custom box for it, what do you guys think?
do a slot ported box u wont be disapointed. I have a 12" fi Q seris sub and used to have a btl. both subs a amazing. and the bl is right in between the two. what kind of music u listen to??
you guys don't think there is enough air space for 1 15" BL?
brickloaf do u mean u wish u did a 12?
i listen to rap lol hip hop you know the stuff that hits real nice a deep
Last edited by musifreak190; 11-29-2009 at 04:35 AM. Reason: Automerged Doublepost
idk if the BL requires as much space as the BTL, so you might be able to get it to fit
the airspace requirement from the bl and btl is very similar. Its a little smaller (save some on port space, no double face and overall space) but not too much
If you made the box and a face like mine has to seal off the trunk and have it facing forward that would be a nice loud setup. Otherwise a 12 will be a much better option
Damn it would be such a hard fit to get a 15" into a cobalt trunk. With the jl 13w7 in its to spec box, all the back seats had to be remove and i had to use my legs to push it through the opening. I would bet it would be possible, I'd be worried about having enough high clearance for a 15" sub though. Either way, good luck.
Here is a photo of mine installed, not so much room for height. I'll take another pic later today from the inside to show height problem.
ahhh thats sucks the trunks in these cars **** me off so much... im probably gonna go with one bl 12 than...u think id be better with two bs 12's like L7's or something or
do u think with the correct box and a 1500w rms mmats amp i could make this hit hard??
RE MX 15" in custom box
Diameter of 12 spoke 15" basket (on all fi woofers) 15.625”, MX basket 16"
when you try hard enough you can make alot of things "fit" doesn't mean its a good idea
bl will sound better then L7 hands down... assuming u have good custom boxes for each setup spl will be
on 1500w 1 bl 12 < 2 L7 12s
on 2000w 2 bl 12s > 2 L7 12s
on 1500w 2 bl 12s ~= 2 L7 12s (hard to say)
Diameter of 12 spoke 15" basket (on all fi woofers) 15.625, MX basket 16"
i have an RE SX12 in a slot box i made to spec(even though RE is a little ff with there specs), and a hifonics 1000/1 rms amp and that thing pounds, but i destroyed my sub by putting too much **** in the trunk and i now have a whole in the sub and the rubber foam surround has gashes and **** in it, so at somepoint im going to upgrade to the next step, what ever that is at the time im looking to buy, but i highly reccomend RE products......
sorta not really... the original owners of RE were scott and david... they sold the company and scott made FI, david later started the team PSI you see around making recones. when fi was still new most of the subs were very very similar to the RE ones but now theres a few diffrences (they are still similar in many ways thou) the current RE subs are still 90% the same as before scott left the company
I listen to a lot of rock and not as much rap. I dont listen to a lot of low bass. Though the DD 8's have impressed me with how low and how loud they can be for an 8. Theres a guy with a dodge ram that competes down at Mach 1 audio in washington at the sound offs and its a standard cab ram a custom 3 8 box and I think he said an 1100 watt amp. And he does low 140s all day long.
hah yea prob at like 70-80hz or something high as **** like that
i cant believe we live in the same tiny city and youve never seen me driving before, its impossible to miss
based on the background of some of your pics im going to guess you live in the apartments across from city hall/popo station
As far as my car still not much setting me apart. About to be lowered on eibach prokits... I have an led license plate light,tint and im debadged thats about it.
