AutoPage alarm and OEM alarm are not being friends.
Old 09-02-2015, 01:13 PM
brickloaf's Avatar
I had an alarm installed years ago and over the past few months when I lock the car, it does the normal AutoPage "chirp" noise, but the short stock horn honk that signifies the car locking also occurs simultaneously. I have never had this issue before, and the only way I have been able to get around this is by unplugging the horn. Obviously having my horn unplugged while driving around is a terrible idea. I was just curious if you anyone knows how to get around this? Basically a way to shut up the stock alarm, if that makes sense. Any help would be appreciated!
Old 09-06-2015, 03:20 PM
LsCobalt07's Avatar
This is copied from the owners manual if you don't feel like reading through this wall of text. Pages 183/184
To change feature settings, use the following
procedure:
Entering Personalization Menu
1. Turn the ignition on while the vehicle is
stopped.
To avoid excessive drain on the battery, it is
recommended that the headlamps are
turned off.
2. Press and hold the information and
reset buttons at the same time for
one second, then release to enter the
personalization menu.
If the vehicle speed is greater than 2 mph
(3 km/h), only the UNITS menu will be
accessible.
3. Press the information button to scroll through
the available personalization menu modes.
Press the reset button to scroll through
the available settings for each mode.
If you do not make a selection within
ten seconds, the display will go back to the
previous information displayed.
Personalization Menu Modes
OIL LIFE RESET
When this feature is displayed, you can reset the
engine oil life system. To reset the system,
see Engine Oil Life System on page 292. See
“OIL LIFE” under DIC Operation and Displays on
page 178 for more information.
UNITS
This feature allows you to select the units of
measurement in which the DIC will display the
vehicle information. When UNITS appears on the
display, press and hold the reset button for at least
one second to scroll through the available settings:
ENGLISH (default in United States): All
information will be displayed in English units. For
example, distance will be shown in miles (mi)
and fuel economy in miles per gallon (mpg).
METRIC (default in Canada): All information
will be displayed in metric units. For example,
distance will be shown in kilometers (km) and fuel
economy in liters per 100 kilometers (L/100 km).
Choose one of the available settings and press the
information button to select it and move on to
the next feature.
-page 183-
LOCK HORN
If your vehicle has Remote Keyless Entry (RKE),
this feature, which allows the vehicle’s horn to
chirp every time the lock button on the RKE
transmitter is pressed, can be enabled or disabled.
When LOCK HORN appears on the display,
OFF (default): The horn will not chirp on the first
press of the lock button on the RKE transmitter.
The horn will still chirp on the second press.
ON: The horn will chirp on the first press of the
See Remote Keyless Entry (RKE) System
Operation on page 89 for more information.
the information button to select it and move on to
the next feature.
UNLOCK HORN
chirp on the first press of the unlock button on the
RKE transmitter, can be enabled or disabled.
When UNLOCK HORN appears on the display,
OFF (default): The horn will not chirp when the
unlock button on the RKE transmitter is pressed.
the unlock button on the RKE transmitter.
the next feature.
-page 184-
Old 09-06-2015, 04:46 PM
brickloaf's Avatar
You sir, are a god among men. Never did I think that would be an option in the DIC. I will name my first child after you.
Old 09-06-2015, 05:55 PM
LsCobalt07's Avatar
Thanks haha
2009blackSS
09-30-2015 05:57 PM
Trav3480
09-28-2015 02:46 PM
jas09ss
09-26-2015 01:06 PM
Builttss
09-22-2015 12:42 AM
SS_2009_TC
09-11-2015 05:41 PM
Quick Reply: AutoPage alarm and OEM alarm are not being friends.
