Can Tech2 change wiper's count when spraying fluid?
Hi team,
During winter, I have to use a lot of windshield washer fluid, especially on snowy days.
Every time you press the windshield washer, after spraying fluid, the wipers cycle about 4 times.
The problem: 4 times is a lot!
Can Tech2 reduce the cycle count for this specific function?
I am about to bring car to garage so I was wondering if this is possible.
Thanks.
Thanks.
No you cannot change the cycle number, its in the programming. So unless you can write code
for the bcm its the way it is.
After the second pass, it just wipes dry, which kills the wiper and worst, keeps making that horrible noise.
I thought maybe a Tech2 could change this...
Just like a Toyota Tech2 can change the number of blinking when you barely touch your left lever.
