Power Source
Old 03-28-2009, 05:35 PM
HunterKiller89's Avatar
Power Source
Hey guys..quick question. I need to find a switched power source to use for my power windows im gonna be installing, and need to know where i should tap them. I already have a couple things (piggyback/gauges) tapped into the ignition wire, and I don't want to run too many accessories off of that one source, and for some reason, no current flows through the sunroof fuse in my car, so I can't tap that one. Would it be ok to tap into the power lock fuse for the power? Or does it need to be a switched source? Anyway, do you guys know of any switched power sources inside the car (passenger side fuse box) other than the sunroof and ignition?
Old 03-28-2009, 10:31 PM
stinkyfisherman's Avatar
I looked it up and it said at the key the acc wire is brow use that if its a larger gauge wire to tap power for the windows
Old 03-29-2009, 12:13 AM
EmperorJJ1's Avatar
the gigantor brown wire is the cars acc which can be taped but it sounds like you may want to run a relay for some of that stuff to make ur life a lil easier
Old 03-29-2009, 01:08 AM
elaborate please? Im semi nubbish when it comes to car electronics. I only know basic electronics, and how to use a soldering iron..lol
Old 03-29-2009, 01:20 AM
EmperorJJ1's Avatar
an automotive relay is basically a big switch. you get power using a nice thick cable to the battery (or in this case probably the fuse box up front) and connect the switching source to your ignition wire (or whatever). This draws all the power from that separate wire your ran and only gets mili amps from the ignition wire so you dont have to worry about overloading the fuse
stinky being a bby installer can probably explain this a little better. Ive only had select experiences with relays
Old 03-29-2009, 02:00 AM
i think i got ya. Power source would be the jumper posts up front, or the battery, whichever is easiest (I imagine up front would be easier), but the connection is broken at the point of the relay. When wires from the relay to a switched power source have current flowing (aka key is ON), then the relay closes the circuit from the battery to the windows. Is this correct?
Old 03-29-2009, 03:06 AM
EmperorJJ1's Avatar
pretty much ya?
Old 03-29-2009, 03:07 AM
EmperorJJ1's Avatar
ya pretty much
Old 04-02-2009, 09:22 PM
...would power windows even need to be powered from a switched power source? I cant imagine any power would be drained unless one of the motors were moving...?
Old 04-03-2009, 11:30 AM
EmperorJJ1's Avatar
???? no idea man
Old 04-03-2009, 02:58 PM
mm...yea, it needs to be switched. the LEDs for all the buttons will be illuminated when the car is off if its not switched... thats incredibly annoying....lol
i guess ill just try the relay thing
Old 04-03-2009, 07:24 PM
EmperorJJ1's Avatar
k its called a "Bosch Style Automotive Relay"
Old 04-03-2009, 11:48 PM
^^ yea, i bought it a couple days ago. I just really wanted to avoid using it... The simpler it is, the better for me
DarrenGC
12-24-2021 01:55 PM
Zharrington_2010LNF
02-08-2016 01:43 PM
hacadacalopolis
10-28-2015 06:09 PM
ernnyyes
10-02-2015 05:16 PM
Stuff
10-01-2015 05:47 PM
Quick Reply: Power Source
